Please , Tell me how to pexilate a face with MovingParts filter ?
http://www.stagetools.com/downloads/PremiereParts.exe
When I load the filter , define the starting frame & the end frame , I get the face pexilated , but it is constant .... I want the filter moves on the face every where the face moves.
I don't know What to do.![]()
You need to use keyframes to control when and where the blur moves. If you are unfamiliar with keyframes (a concept common to most, if not all, editing software), I suggest you do a Google search.
Here's the manual for the software: http://www.stagetools.com/PartsManual.htm
Brainiac
Than Q So much 4 response , I read the tutorial but it got over my head .... Do u know any other way to pexilate a moving face in Adobe PremiereOriginally Posted by Brainiac
I just did a Google search and found this tutorial: http://www.wrigleyvideo.com/videotut...o_blurface.htm
I'm sure there are other ways too, but this should get you started.
Brainiac
Than Q So much 4 the tutorial ... It is very good ... I could do it successfully.
XMedia Recode Crashes when going to "Filter/Preview" tab
By BoxesofBags in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2012, 12:46 -
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 00:03 -
VirtualDub Filter for problem with "Horizontal Sync Issues"?
By lonerzzz in forum RestorationReplies: 6Last Post: 6th Apr 2009, 17:29 -
Vdubmod "Source image format incorrect" when cropping with filter
By Gruelius in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 19:37 -
NAME="mplayerc.exe" FILTER="GRABMI_FILTER_PRIVACY"
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2008, 15:40
