Hello All,
I just downloaded the latest version of Virtualdub and installed DivXinstaller so Virtualdub could work with AVI files. Works fine. Now I want to work with a file that is in the MPEG2 format. I read that Virtualdub does not support MPEG2. Should I convert the MPEG2 to AVI or is there another fix? Also, are there any other updates or downloads that I should make to Virtual dub? Thanks, Bill
Here is what Mediainfo says about the file:
General #0
Complete name : E:\Movies\Wedding Video\Wedding Video 11_3.mpg
Format : MPEG-2 Program
Format/Family : MPEG-2
File size : 3.50 GiB
PlayTime : 1h 28mn
Bit rate : 5636 Kbps
Writing library : Created by Nero
Video #0
Codec : MPEG-2 Video
Codec profile : Main@Main
Codec settings/Matri : Standard
PlayTime : 1h 28mn
Bit rate : 9383 Kbps
Bit rate mode : CBR
Width : 720 pixels
Height : 480 pixels
Display Aspect ratio : 4/3
Frame rate : 29.970 fps
Standard : NTSC
Chroma : 4:2:0
Interlacement : Bottom Field First
Bits/(Pixel*Frame) : 0.906
Audio #0
Codec : AC3
PlayTime : 1h 28mn
Bit rate : 448 Kbps
Bit rate mode : CBR
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, Subwoofer
Sampling rate : 48 KHz
Video0 delay : -2ms
Virtualdub-MPEG2
VirtualdubMOD
I think there might be some plugin for the regular Vdub to open mpg2 files but i'm not sure as i use the first one i posted for working on mpg2 files.Originally a member since 2001, LONG LIVE TARAN's!!!
File input plugins for VirtualDub @:
http://home.comcast.net/~fcchandler/index.html
Virtualdub can load and edit mpeg-2 files, however it cannot directly output them. For that you need to frameserver to an mpeg-2 encoder.
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 02:49 -
virtualdub mpeg2-vob to avi problem
By darc15 in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2005, 23:37 -
Help Converting MPEG2 With VirtualDub-MPEG2
By trickyman in forum Video ConversionReplies: 19Last Post: 20th Oct 2004, 16:03 -
Mpeg2 audio playback is choppy, Virtualdub-mpeg2
By Patriots in forum AudioReplies: 0Last Post: 29th Jul 2004, 00:10 -
Best way to convert MPEG2 to AVI so I can use VirtualDub??
By drewson99_99 in forum Video ConversionReplies: 14Last Post: 26th Nov 2002, 14:31
