Greetings,
After searching the forum for all things PVR-250 related , I still couldn't find an answer , so I'm hoping maybe someone here can offer a little advice.
Does anyone know if the card itself or the WinTV2000 software has more than one area for adjusting the color settings? For example , I have two sources connected via s-video , one using the card's on board connector & the other using the additional AV bracket found on the Hauppauge website.
Source 1 , is the cable converter , and the quality of capturing is amazing , thanks to a few tweaks found on this board as well as in the Hauppauge Tweaker.
Source 2 - also connected via s-video (bracket) , is the vcr for doing tape transfers. As mentioned on here time & time again , the colors are sometimes washed out , and whites are very bright. This happens though , no matter which source I'm connecting the VCR to. However , using a 2nd display video monitor I can see the colors are fine , so I know it isn't the VCR.
Swapping the VCR to either source does the same thing. If I adjust the colors to much , this alters the recording for Source1 , which as I mentioned is already perfect.
Any ideas on what I could try? Would switching the VCR output into the 250 from svid to composite make a difference?
I hope all this makes sense. Thanks in advance.
Your VCR has s-video output?
Yes. I'm using the Panasonic AG1980.Originally Posted by jagabo
If you're going to be a wiseass jagabo , just piss off! I don't need any help if it comes in the form of sarcasm.Originally Posted by jagabo
I guess the 250 is just an old dinosaur that nobody uses anymore. Forget I asked.
I wasn't being a wiseass. Your thread got lost among all the other I participate in.
I was trying to figure out if my PVR-250 had a second s-video input port. When I flip through the inputs using WinTV2000 it shows two composite inputs but only one s-video input. I was going to test the second input but I guess I won't bother now.
I try to avoid people that appear to be bipolar.
Oct 26 is friendly asking for help. Oct 29 is rude. I don't get it.
Anyway, consider getting yourself a proc amp.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Image sequence - VirtualDUB - HuffYUV - washed colors
By Bucic in forum EditingReplies: 35Last Post: 8th Oct 2010, 14:42 -
Hauppauge PVR-250 software question
By Ogilvy in forum CapturingReplies: 19Last Post: 28th Sep 2010, 02:11 -
PVR-250 and Capture Software
By statman24 in forum CapturingReplies: 5Last Post: 27th Nov 2008, 13:38 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum CapturingReplies: 10Last Post: 5th Mar 2008, 02:19 -
new pc and my hauppauge pvr 250
By heman28 in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Jan 2008, 07:33
