VideoHelp.com Forum
    Hello All,
    I downloaded a trial of PowerDirector 8 last night and it seems like a pretty comprehensive program. I think the retail cost on it is like $80 or so. The problem is I dont see myself doing that much video editing so I am having a hard time justifying the cost. I dont mind spending money if I am going to use a software program but not if I am only going to use the program rarely.
    I have read and leared what I can about VirtualDub. I will download it to my PC tonight to give it a try. Here is what I want to do with a program:
    Basic editing - primarily removing unwanted portions of video
    Capturing - I bought a USB capture device. Can't remember the name but it works pretty well. Capturing will not be a primary need. More of a nice to have.
    Can VirtualDub fix sound problems, ie if sound is out of synch can the sound be sped up or slowed down to match the video.
    Lastly, I want to be able to burn the video to DVD. Does VirtualDub have this functionality or should I try something else? I have used DVD Flick which works pretty well.
    Thanks, Bill
    Yep, you can do basic cutting(use video and audio -> direct stream copy to avoid reconversion), capturing and also adjust some sync issues(audio->interleave) but not any dvd conversion.
    So try it! and if you get stuck be sure to google for a guide.
  1. VirtualDub - fixing bad frames with blending and without re-encoding
    By spicediver10191 in forum Video Conversion
    Last Post: 11th Apr 2012, 08:15
  2. Fixing / hex editing a corrupt MP4 - paid work?
    By geefin in forum Newbie / General discussions
    Last Post: 22nd Feb 2011, 03:19
  3. Fixing sound sync issues in a mkv file
    By Psykro in forum Editing
    Last Post: 1st Aug 2008, 05:50
  4. Overscan, Fixing the problem without Editing the avi files?
    By Gabriel87 in forum Authoring (DVD)
    Last Post: 21st Nov 2007, 19:41
  5. Fixing muffled sound on .avi file
    By kman0199 in forum Audio
    Last Post: 7th Jun 2007, 00:40
