Hello everyone,
Whenever I try to import a video in Adobe Premiere CS3, the aspect is all disproportionate. By this I mean that the video I import to edit is smaller than the area of work so there's always blackness around. I realise I need to change the aspect ratios, but I tried EVERYTHING and it never did come out right.
To make all of this easier to understand, here are images of an example:
This is an exported video: http://i34.tinypic.com/293d1s8.jpg
When I create a new project, here are the two tabs I have options with:
http://i33.tinypic.com/345zsrm.jpg
http://i34.tinypic.com/2a9a0so.jpg
I chose DV - NTSC / standard 48KHz in the first window.
In the 2nd window, I chose this: http://i37.tinypic.com/195tw6.jpg
This was the result: http://i36.tinypic.com/wc1j4k.jpg
(I realise now that each tab is a different thing, I gotta choose either the first (pre-made presets) or the second (custom stuff) but oh well)
Another btw, notice how I can resize the video in the right working zone?
http://i36.tinypic.com/1h77ly.jpg
Issues: 1- it’s not widescreen like the video itself.
2- It’s still not a perfect fit even if I stretch it..
If you have the patience to load a 22MB movie, go check the last one I did despite this issue at http://www.digitalkarl.com/Salameh_Karl_TP2.mov
After the part where it says "When those who bred you to kill ... ... since your very birth" notice how the fade-to-white effect actually happens on ALL the working area? Well that gives you an idea of how the videos I import never seem to fit to the whole screen, only a small area in the middle.
I've been trying to fix this issue for months now, I truly need help.
Thread: Aspect ratio issues.
Don't use NTSC DV preset. Your import asset is 704x336. Set to square pixel 1:1, 23.976 fps, and progressive as custom settings. Your sequence settings should match your content
Samsung DVD 850 - aspect ratio issues
By monty1977 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 15:43 -
aspect ratio issues ffmpegX
By wiserthanu in forum MacReplies: 2Last Post: 2nd Jul 2006, 09:29 -
Aspect Ratio Issues..
By calhoun in forum Newbie / General discussionsReplies: 11Last Post: 30th Dec 2004, 04:03 -
Aspect Ratio Issues
By mojo-pin in forum MacReplies: 0Last Post: 29th Nov 2003, 14:39 -
Aspect Ratio Issues - DiVX to SVCD
By techboy_66 in forum Video ConversionReplies: 1Last Post: 2nd Dec 2002, 06:50
Statistics
Newest guides
Latest tool updates
New media comments
