So here's the deal, as long as I do one film at a time, I have no problems. But when I set it up to batch process is when things go screwy. It will go through all the processes just fine and the output files are ok. But when it runs the end script or whatever that tells you the overall results for each batch the runtime error pops up. When you click ok, rebuilder closes out. Then when you open it back up, all settings have been lost. It says default skins have been updated, all the locations for the encoders have been lost, and so on. So I go to all the trouble of fixing the settings and try to run another file through it, but receive an error saying that my encoder does not appear to be functional. I am using HC Encoder by the way. The first time this occurred, I even went to the trouble of removing and re-installing the program. Evidently that did not help. I could sure use some help here as I have never had this happen before. Thanks.
I have not seen this bug.
Search or ask in dvdrebuilders official forum over at doom9, http://forum.doom9.org/forumdisplay.php?f=75
VOB2MPG Batch Processing
By jonj1611 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Aug 2011, 13:35 -
Batch Processing
By keefytee in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 7th May 2011, 04:41 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
Batch processing .AVI
By R2 in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2008, 20:34 -
Batch Processing
By ruggie_uk in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 19th Jul 2007, 06:04
Statistics
Newest guides
Latest tool updates
New media comments
