VideoHelp.com Forum
    Hi Everyone,
    I have an audio problem while burning .avi movie to a dvd with Adobe Encore (actually also with Nero).
    The strange thing is that not all the audio is gone, some pieces are still there, but mostly there is no sound at all. Unfortunately I only got an exported avi file (All the audio layers are melted together) left to work with.
    Another thing I don't get is that when I import my file into Premiere all the audio is still there. So the file seems good, but in fact something isn't right?! The dvd burning software (Encore and Nero) has skipped the same audio parts. When I play the dvd on my computer it works (all the audio is there) but when I try to play it on several dvd-players (connected to the television) the same audio problem occurs. The audio problem only occurs with one file, i burned to .avi's on the dvd, the other one is fine.
    I really hope you can help me out!
    Thanks a lot!
    Jochum
  2. Member t0nee1's Avatar
    I don't use Adobe Encore or Ner0, so can't comment on them..My guess is, the apps used are not creating a proper DVD..What are the specs of the audio, MP3, perhaps?...If so, use ac3..Better yet, try something like DVDflick or ConvertxtoDVD which will create a proper DVD for you...
    Perhaps someone that uses the proggies you've mentioned, will chime in..
    Good luck!.
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
  1. Audio problems after ripping DVD
    By ksimz202 in forum Newbie / General discussions
    Last Post: 28th Mar 2011, 01:49
  2. Audio problems on my dvd
    By leemorley in forum Newbie / General discussions
    Last Post: 20th Sep 2010, 03:55
  3. audio problems when burning a DVD
    By cosypete in forum Authoring (DVD)
    Last Post: 9th May 2010, 18:23
  4. DVD Audio Problems
    By 557953 in forum Authoring (DVD)
    Last Post: 25th Jan 2008, 14:42
  5. Help with audio problems on dvd-lab pro and / or subtitles on a dvd
    By Jack the Ripper in forum Newbie / General discussions
    Last Post: 7th Dec 2007, 18:00
