Hello,
I have DVD rekorder SONY RDR-HXD990. I often burn movies on DVD disc. DVD-R, DVD+R work fine. Today I wanted to use DVD+RW medium for repeatable burn. First burning is o.k. but the second one is impossible. DVD recorder tells: Insert recordable disc. What do I do wrong? I tried formatting after first burn and erasing as well. Nothing has helped.
Thanks for help
ipo
Erase it on your computer?
Also try better media (use Verbatim). Also try a different disc. In my experience DVD+RW discs sometimes have problems much sooner than they are supposed to. When I have one that seems to have problems, I just throw it away and use another disc.
Convert NTSC DVD and rewrite to PAL
By murihikukid in forum Authoring (DVD)Replies: 3Last Post: 12th Sep 2011, 07:48 -
Total Newbie -- Best/cheap way to rewrite a Region 2 DVD to Region 1
By jteselle in forum Newbie / General discussionsReplies: 6Last Post: 3rd Nov 2009, 11:49 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Insignia IS-DVD1001 DVD VHS Recorder combo Firmware -- What +R Media
By bulajim in forum MediaReplies: 1Last Post: 20th Jan 2008, 15:27 -
Did "Good" media go bad -OR- DVD Recorder conundrum? Help!
By MrCreosote in forum MediaReplies: 9Last Post: 11th Sep 2007, 19:33
Statistics
Newest guides
Latest tool updates
New media comments
