    Hey guys, wondering if you can help out. I have an old Canopus ADVC100 that used to work flawlessy with Windows XP years ago when transferring VHS tapes.
    Since then, I've upgraded to a new computer with Vista 64 and, for some reason, I cannot get this thing to work anymore. When I plug it in via firewire, it appears that Vista recognizes it, but then when I hook it up to my VCR, I'm not getting anything at all coming through. Neither Adobe Premiere Pro CS4 or Windows Movie Maker seem to even recognize its existance.
    Is there a possible fix that I'm missing or do I need to upgrade to the Canopus ADVC300 or something more modern?
    Thanks!
  2. Member edDV's Avatar
    Thanks!
    The Canopus ADVC-100 is a hardware analog to DV (IEEE-1394) device. It has no drivers and shouldn't differ between OS versions. It is just DV. No machine control, just a DV stream source.
    The problem is other.
    You obviously had to reinstall CS4. Did you remember to turn off device control?
    Did you try WinDV?
    The ADVC-300 will not differ. The ADVC-300 remote control software may not be Vista 64bit ready.
    PS: I have my ADVC-100 working flawlessly with Mac OSX, XP, XPpro, Vista Home Premium, Vista Ultimate and the Win7 RC. I'm not using 64 bit yet on any of these because of driver or application support issues.
    http://www.kiva.org/about
    Yeah, I understand what the device does, but I was just checking to make sure that Vista wasn't the problem. Perhaps a firewire setting in the device manager or something. It was listed there as working properly, but wanted to be sure.
    I didn't turn off the device control, but it didn't work with Windows Movie Maker either which led me to believe there could be a problem.
    Haven't tried WinDV though. Might try that next.
    Ah, success with WinDV! Nice! Thanks for the recommendation on that. Would have probably never thought of it myself.
  5. Member edDV's Avatar
    CS4 and Vegas DV capture have too many settings to trap you. WinDV is a pure play.
  1. VCDEasy doesn't work in Vista...
    By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)
    Last Post: 26th Dec 2010, 21:20
  2. The Sims 2 Doesn't Work On Vista?
    By Nitro89 in forum Computer
    Last Post: 19th Nov 2008, 05:09
  3. Doesn't work with Vista SP1
    By hordak in forum SVCD2DVD & VOB2MPG
    Last Post: 14th Mar 2008, 16:19
  4. Does TMPGenc Plus 2.5 work on Vista Ok?
    By leegutcher in forum Newbie / General discussions
    Last Post: 6th Jul 2007, 08:22
  5. TMPGEnv plus 2.5 work in Vista?
    By yogart in forum Video Conversion
    Last Post: 20th Apr 2007, 19:48
About   Advertise   Forum   RSS Feeds   Statistics   Tools
