VideoHelp.com Forum
    The manual that came with my graphics card states that for graphics card that have an auxiliary requirement, you must connect the AGP 4 pin molex adapter, the 6 pin PCIE molex adapter or the 8 pin PCIE molex adapter or in some cases, both the 6 pin and 8 pin adapters.
    How do I know if my graphics card has "an auxiliary requirement"? It is a GTX260.
    Another thing I wanted to ask is about the mains PSU cable. I have a good quality PSU. Would using the mains cable from an old computer be ok? I also have a new unused cable which I can't remember where I got from. Would it be safe to use this cable or are there similar cables available which look exactly the same as a PSU cable but are for some other device completely? (Yes, it is definitely a computer related cable and not from a kettle or deep fat fryer!!) Thanks.
  2. I'm a Poll Super Moderator johns0's Avatar
    I have a 260gtx video card and it uses 2 6 pin connectors from my psu,just look on the card and see what connectors it requires,any mains cable will work if they are in good condition.
    Ben Johnson-I didnt take any stereos!
    Thanks johns0.
  1. VGA-cable from graphics card to LCD TV
    By badtant in forum Software Playing
    Last Post: 10th Jul 2011, 20:26
  2. Replies: 9
    Last Post: 11th May 2011, 15:51
  3. Specific video card requirements for HD playback?
    By GLE3 in forum Newbie / General discussions
    Last Post: 1st Apr 2009, 12:12
  4. Replies: 3
    Last Post: 15th Oct 2008, 14:50
  5. What sort of Graphics Card/Capture Card to get
    By Dr_trout in forum Capturing
    Last Post: 24th Jul 2007, 15:19
