hi,
im a movie watcher and i like to have the best scenes of my best movies or videos splitted from whole video ...
is there a software for splitting almost all video formats (all codecs ...) ?
i watch H264 movies, blue ray Iso images, dvd movies, maybe a short 3gp video ...
i dont want to re-encode the movie ... just splitting it with same quality and format ...
thanks,
Thread: a video cutter
No.
But avidemux supports lots of formats.
does it work with HD movies ?!
but it doesnt output the audio correctly ...
what do u have specially for MKV format / H264 Codec ?!
There aren't many editors for mkv with h264. avidemux is probably best but it wont work perfect as you have noticed...
Another option would be to use mkvtoolnix to split, but it has not a video interface so you have to type in the time codes where to cut.
I just tried mkvtoolnix to split an mkv file in two and once you have figured out the correct time codes (I tried avidemux as it gives the ms but the time codes were not correct so I used vlc) it takes only a few minutes to do the job.
Thank you Baldrick
Can't Click Destination Folder in Xilisoft Video Cutter
By props1oh1 in forum EditingReplies: 2Last Post: 13th Feb 2009, 19:17 -
Video cutter/splitter
By alintatoc in forum Newbie / General discussionsReplies: 5Last Post: 29th Jan 2009, 07:01 -
Frame accurate dvd video cutter?
By madsharpei in forum Authoring (DVD)Replies: 6Last Post: 15th Jun 2005, 09:13 -
VOB Cutter Like VCD Cutter
By amitabhbansal in forum EditingReplies: 1Last Post: 9th Sep 2004, 08:00 -
Can't use tmpgenc or easy video cutter
By mumba in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st Aug 2003, 11:47
