Hey Everyone!
First of all I'm pretty much a n00b when it comes to anything having to do with video editing/playing/converting etc.
I've used a plugin called PlayFLV in order to allow my WMP10 to recognize and play FLV files on my computer. In conjunction with that I also use ffdshow (rev 3097 - Oct. 8th 2009) in order to decode FLV video files.
This works great, and I can simply play FLV files right inside WMP10 by double clicking on them like any other video file (avi, mpg etc.).
However, there is a problem... on occasion I get FLV files which I cannot play inside WMP10. When I double click to open them I just get a message that WMP10 cannot recognize the format.
The only program I seem to be able to open these FLV files from is FLVPlayer, which I don't really like to use that much, and would prefer to be able to play ALL video files from WMP as I'm doing right now.
In order to try and find out what's so different about these certain "unplayable" FLV files I loaded them from FLVPlayer and clicked on the "Info" button, and low and behold, they all have some commonalities:
In the above example where the video codec ID is "avc1" and the codec name is "H.264", the video will not play only if it's an FLV file. I found that MP4 files which have exactly the same encoding play without any problems.Originally Posted by FLVPlayer 1st example (CAN'T PLAY)
So clearly in this instance ffdshow is definitely capable of decoding the video codec if the container is MP4, so why on earth can't it also decode when the container is FLV?!
In this example (and this is the most common occurrence), I get video codec ID as "7", and the video codec name is "undefined". These FLVs will only play with FLVPlayer and nowhere else.Originally Posted by FLVPlayer 2nd example (CAN'T PLAY)
So what exactly is this video codec who's ID is "7" and how can I play these files outside of FLVPlayer??
Just to contrast the above 2 examples, MOST of the flv files which I CAN PLAY are these:
This is like 99% of all of them!Originally Posted by FLVPlayer 3rd example (CAN PLAY)
*SOME* are also this:
So when it's "Sorenson H.263" it's also not a problem.Originally Posted by FLVPlayer 4th example (CAN PLAY)
I've tried to search online for a solution last night, but couldn't quite find any solutions which are specific to my problem. Also I tried to completely uninstall and then re-install the latest rev of ffdshow, and that didn't seem to do anything!
If anyone can offer me any information about how to solve this problem I would greatly appreciate it!
Thanks for taking the time to read everyone!
John
Thanks a lot poisondeathray!!
I actually ended up uninstalling "PlayFLV", and installed the FLV Splitter instead, and now all FLV files play perfectly! :]
Since like I said I already was using ffdshow, that needed no re-installation or anything! Didn't even have to restart my computer, it started working immediately!!
Just one final question; After I install the FLV Splitter using "regsvr32 FLVSplitter.ax", do I still need to keep the FLVSplitter.ax file in the location from which I installed it, or can I now just delete it?
Thanks!
Burnt DVD with vob problem (not playing on computer)
By lamaddvd in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2009, 14:28 -
FLV files now playing stereo by default on YouTube?
By brassplyer in forum Video StreamingReplies: 1Last Post: 13th Feb 2009, 18:26 -
Playing flv files with WMP
By INFRATOM in forum Software PlayingReplies: 1Last Post: 22nd Jan 2009, 03:12 -
Problem playing dvd's on computer
By easye35 in forum Software PlayingReplies: 5Last Post: 18th May 2008, 00:30 -
Youtube .flv files quickly stop playing but will play past half way point
By video1312 in forum Software PlayingReplies: 1Last Post: 20th Sep 2007, 13:20
Statistics
Newest guides
Latest tool updates
New media comments
