Hey folks. This is likely another dumb question from me, but I thought my 5990 would just squash this rez down on my CRT. When I try to play it simply says "resolution not supported." It was the second time in one day that I've had a file not play in this box. The other was in H.264 but I had no idea until I checked it on the the desktop, and yeah, I know the 5990 won't play this format.
Cheers,
Wanderlustus
The 5990/5992 top out at 720 horizontal pixels. Your square pixel 852x480 video needs to be H squeezed down to 720x480 (non-square pixel) and flagged "wide" just like is done for DVD.
If your format doesn't support anamorphic wide flags then you need to rescale to near square pixel 720x400. 400 is divisible by 16, 405 (square pixel) isn't.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Thanks for the info, Ed. Might just be one I watch on the desktop I guess.
Cheers,
Wanderlustus
852 > 720
so no playback for you until you transcode/resize to a format the deck will play
AviDemux
SUPER (atrocious: scatters files all over)
mediacoder 0.6 (0.7 is not open source)websearch: The Peoples Cube
Er, yeah. I think Ed covered this in his post, and I've already watched said bit on my desktop, so it's not really an issue any longer.Originally Posted by HalfAzPVRCheers,
Wanderlustus
Originally Posted by WanderlustusSince you didn't seem to have the information you needed to play on your STB I provided some. I didn't realize you were both lazy and snarkyOriginally Posted by Wanderlustus
try to live happily.. you'll live longerwebsearch: The Peoples Cube
HalfAzPVR, it's seems to me you're the snarky one. You didn't provide any newer info, and it seems to me that you're the one who needs to live a little more happy, instead of trolling forums trying to impress yourself. Have a great day, you're going to need it.
Cheers,
Wanderlustus
DVP 5990 and Exteranal HDs
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 18Last Post: 31st Jan 2010, 10:02 -
DVD Philips DVP 5990
By heidizwygart in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd May 2009, 05:48 -
Philips DVP 5990/37 question.
By s-toon in forum DVD & Blu-ray PlayersReplies: 16Last Post: 12th Apr 2009, 15:44 -
Philips DVP 5990/92 and DVD Media
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Jan 2009, 19:51 -
Phillips DVP-5990 - HDMI problem?
By Ai Haibara in forum DVD & Blu-ray PlayersReplies: 5Last Post: 3rd Jan 2009, 02:18
