    hello
    how should i know how to define to video bitrate
    when recording in the tv card
    now its standing on 65000
    how does it works?
    if i will climp it up the quality will be better or what?
    What card ?
    What capture software ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    What source?
    What cabling?
    What filtering will you be doing?
    What final output (DVD, Youtube, etc)?
    65000? Do you mean 6500 kbps?
    card: Compro M1F
    software capture: Compro DTV4
    cabling: S-Video
    output: DVD (mpg)
    filtering: what do u mean by filtering i didn't understand
    6500 yes
    Since your target is DVD you are talking MPEG 2 encoding with bitrates below ~9000 kbps. If you have less than 1 hour to put on a single layer disc (4.7 GB) you can simply use constant bitrate encoding at ~9000 kbps. The max bitrate allowed is about 10,000 kbps for video + audio + subs. For more than an hour on a single layer disc you should use a bitrate calculator to determine the appropriate bitrate. Then use a 2-pass variable bitrate encoding with the average bitrate set to that value. 2-pass encoding isn't possible while capturing.
    Basically, the higher the bitate the better the quality. The basic relationship between bitrate, file size and running time is:
    file size = bitrate * running time
    Filtering refers to adjusting the picture. Things like contrast, color, sharpening, noise reduction, etc. Filtering can be too slow to do while capturing. If you need to filter, and your card supports uncompressed or losslessly compressed video you should use that. Then filter your video and encode to MPEG 2 for DVD.
  1. Replies: 3
    Last Post: 15th Sep 2008, 03:48
  2. how do i lower the bitrate on my ati card
    By eric35IIx1 in forum Newbie / General discussions
    Last Post: 20th Jan 2006, 13:44
  3. bitrate of source video (Xvid, Divx) VS bitrate of VCD
    By F u r u y á in forum Newbie / General discussions
    Last Post: 12th Mar 2005, 21:12
  4. Replies: 2
    Last Post: 1st Apr 2004, 01:34
  5. Max Bitrate Video Bitrate SVCD,.. 2600 or 2472 ?
    By AE-35 in forum Video Conversion
    Last Post: 19th Jul 2001, 22:53
About   Advertise   Forum   RSS Feeds   Statistics   Tools
