http://link.brightcove.com/services/...id=45614803001
I am trying to download this video (Fan rock the valley) to my desktop. I have tried all different techniques and programs that I have learned on this forum. I just cant seem to get it.. Any help would be much appreciated!
Thread: brightcove.com
This is an rtmp stream
Old versions of replay media capture work
I suspect firefox with the download helper would too
I uploaded it for you here
http://www.mediafire.com/download.php?hkyerykkzwm
Cheers
poisondeathray you are TheBomb.com! i did try download helper and it did not pick it up... thank you so much.
Download Helper has never really worked for me.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Try the Grab Pro tool included with Orbit Downloader. Download Helper only supports http.
pdr - which version of rmc works for rtmp for you? i have v2 and can't get it.
@minidv2dvd - do you remember that big hoopla where rmc became b0rked due to changing the plugins due to pressure from Adobe? There were several posts in this forum and on the rmc forum about this, if you want more info. All new versions apparently become "flashed" with a new plugin_zrtmp , plugin_zrtsp, etc...
My current version is 3.01 ,
plugin_zrtmp 5.2.6.9
plugin_zrtsp 1.2.6.9
There are a few other plugins, but I think those are the relevant ones
What I do is configure my firewall settings so it blocks the flash, so I end up keeping the old plugin versions which seem to work ok on most stuff
ahh crud, now i do. thanks for the reminder. i checked my plugins and you're correct they have been updated without my knowing. going to try and get back the old ones.
thanks
How to Download off Brightcove.tv?
By syracusefan1 in forum Video StreamingReplies: 25Last Post: 30th Jan 2012, 18:31 -
How To Record , Capture, Or Download This Flash Video From Brightcove.com
By hypnoticpimp in forum Video StreamingReplies: 1Last Post: 17th Jun 2008, 14:13
