VideoHelp.com Forum
  1. Member leghorn's Avatar
    Hi folks,
    I've been trying to convert a DVD to mp4 using meGUI with x264. As stated in the subject line I go with x264 r1301.
    When configuring meGUI I have this commandline:
    program --profile high --pass 2 --bitrate 465 --stats ".stats" --thread-input --deblock -1:-1 --b-adapt 2 --b-pyramid --scenecut 64 --ref 5 --rc-lookahead 45 --cqm "jvt" --merange 32 --me umh --subme 10 --partitions all --trellis 2 --no-dct-decimate --no-fast-pskip --no-psy --output "output" "input"
    Then queue and run it...Error message occurs saying
    invalid argument: b-pyramid = --scenecut
    So resetting the scenecut value to its default of 40 actually removes that option from the commandline and things look like this:
    program --profile high --pass 2 --bitrate 465 --stats ".stats" --thread-input --deblock -1:-1 --b-adapt 2 --b-pyramid --ref 5 --rc-lookahead 45 --cqm "jvt" --merange 32 --me umh --subme 10 --partitions all --trellis 2 --no-dct-decimate --no-fast-pskip --no-psy --output "output" "input"
    The queue and run it again...Error message occurs saying
    invalid argument: b-pyramid == --ref
    Prior to r1301 I used r1292 and it worked fine. No problems at all. Maybe anybody has an idea how to fix this? Despite downgrading to r1292...
    MeGUI hasn't been updated yet to reflect the new changes
    The new switches are
    --b-pyramid strict
    --b-pyramid normal
    --b-pyramid none
    none is default, strict is for the new blu-ray compliance (no p-frames can reference b-frames) and slightly worse compression, normal is the old method
    If you are using mb-tree, b-pyramid doesn't work with it yet anyways, otherwise you can turn it off
    --no mb-tree
  3. Member leghorn's Avatar
    well then, it's waiting for an update or manually changing stuff...
    Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
    Development has slowed down on that project, especially compared to the furious pace x264 development. I wouldn't hold my breath waiting for updates.
    Kurtnoise has a beta server, if you update your config in the options, but even that is far behind compared to x264 development
    http://kurtnoise.free.fr/MeGUI/
    The gui is still useable, if you use the commandline box.
  1. Really odd issue playing some x264
    By NotSoEasy in forum Software Playing
    Last Post: 27th Mar 2012, 14:17
  2. Joining x264 mp4 files issue
    By dreamweaver888 in forum Editing
    Last Post: 27th Feb 2012, 18:30
  3. DXVA issue in MPC HC with x264 video
    By Phat J in forum Software Playing
    Last Post: 24th Jan 2012, 14:52
  4. Replies: 7
    Last Post: 5th Jul 2010, 18:24
  5. x264: -1920, -ESiR, -SEPTiC, -CiNEFiLE.... What are these x264 extentions?
    By NWNewell in forum Newbie / General discussions
    Last Post: 18th May 2009, 17:10
