    I have just recently found this program to add subtitle to an existing DVD. It’s an easy program to use, however, I cannot, not matter how I try, getting the subtitle to become white. Every time the program has completed the DVD, the subtitle is somewhat brown with red borders. This also happens when I use preferred subtitle colours.
    Can someone please help me to fix the problem?
    Mark
  2. Member AlanHK's Avatar
    Subtitle colours are not absolute, they are references to a palette, and authoring programs may assume a different one.
    Easiest way to adjust this is to use DVDSubedit.
    This can open an authored DVD fileset and adjust colours (as well as timing and positions) of subtitles.
    Make the change, then "Edit/apply last modifications to all" to change every subtitle, and save.
    So the first thing I do is to convert a srt file to sup, then edit the file in DVDSubEdit, and then continue on in Subtitle creator?
    Mark
  4. No, you complete the DVD with the new subs added in and then when it's all done fix the colors using DVDSubEdit (or PGCEdit).
  1. Replies: 2
    Last Post: 15th Nov 2009, 23:47
  2. Subtitle Creator filter???
    By aslan in forum Newbie / General discussions
    Last Post: 31st Aug 2008, 10:38
  3. Subtitle Creator does not even start!
    By bibo01 in forum Subtitle
    Last Post: 15th Feb 2008, 12:31
  4. subtitle creator problem
    By tRAVALO in forum Newbie / General discussions
    Last Post: 23rd Apr 2007, 11:51
  5. Almost There: Autoring DVD Subtitle Colours:
    By Kurdminator in forum Subtitle
    Last Post: 3rd Sep 2005, 21:16
About   Advertise   Forum   RSS Feeds   Statistics   Tools
