Hi,
Just downloaded all required files and installed successfully.
However, I cannot load the flvtool2. I got the file, decompressed it. The instructions tell me to open terminal.app ....There is NO such file in the folder. I specifically need the flv progress bar to work for my videos, as I am working with flash only....Please, any help is greatly appreciated!
A.
Thread: HELP downloading flvtool2!!!
It is a command line tool and you run it from the terminal in mac , I guess it's under Open Applications -> Utilities -> Terminal and then type the command(flvtool2 video.flv or similar) and hit enter.
And google for terminal mac for some guides, http://macdevcenter.com/pub/a/mac/20...minal_one.html
Terminal.app is an application that came with the operation system. It is on every Macintosh (with OS X). Look for it inOriginally Posted by ajeanette
/Applications/Utilities/Terminal
Help with metadata when converting to FLV using flvtool2?
By Sharon M in forum ffmpegX general discussionReplies: 15Last Post: 27th Jan 2010, 16:23 -
Can't Install FLVTool2
By visioner in forum ffmpegX bugs and suggestionsReplies: 1Last Post: 25th Apr 2009, 06:53 -
Looking for free HTTPS Downloading Manager for downloading video or file
By coody in forum Video StreamingReplies: 1Last Post: 3rd Feb 2009, 13:40 -
FLVtool2 installation problem
By linea in forum ffmpegX general discussionReplies: 34Last Post: 15th Dec 2008, 12:09 -
FLVtool2 doesn't install correctly
By chaosmoon in forum ffmpegX general discussionReplies: 5Last Post: 12th Feb 2008, 19:25
Statistics
Newest guides
Latest tool updates
New media comments
