Hello,
I am new here... I'd like to author a (simple) blu-ray. The source material is .f4v files with the following specs:
Video:
H264
1280 x 720
aspect ratio = 1:1
frame rate = 23.976
Audio:
AAC
128 kbps
44100 Hz
Can I use these files without re encoding them? what program could I use?
Thanks,
diodorus
Thread: Blu ray from f4v
The audio must be reconverted but the video might work without reconverting. Try multiAVCHD and see what it says.
If it wont work try an all-in-one blu-ray/avchd converter like avchdcoder, d2mp.
ok, since multiAVCHD wouldn't take f4v files as inputs, i first used avidemux and transformed the f4v's into mp4's (no re encoding, right?).
then i put the mp4 into multiAVCHD, which, as you predicted, (if i understood correctly) only re encoded the audio... i then created an iso with imgburn and it played correctly in powerdvd.
that all went too smooth, as a first experiment!!
if i now want to create a a blu ray with menus, can u recommend any software i could start playing with?
thanks!!
diodorus
edit: i have just noticed the menu section within multiAVCHD. i'll start playing with this first, but i assume it's not very versatile...
If you use video COPY and audio COPY in avidemux there will be no reconverting, just remuxing to a mp4.
For more advanced menu creation you can use tmpgenc authoring works or http://www.videohelp.com/tools/secti...ring-bd-hd-dvd . BUT most of them might reconvert your video....and they aren't exactly free.
Are there any 100% working methods for Blu-ray TO Blu-ray ?
By Tyrexionibus in forum Blu-ray RippingReplies: 8Last Post: 19th Oct 2009, 09:55 -
xvid4psp, encoding settings suggestions please, blu-ray-> blu-ray
By runLoganrun in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 09:07 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 13:48 -
First Blu-ray disc drive won’t play Blu-ray movies
By akrako1 in forum Latest Video NewsReplies: 15Last Post: 14th Aug 2006, 00:30
Statistics
Newest guides
Latest tool updates
New media comments
