Hi all, I videotaped some pro wrestling over the weekend with a 3 cam seteup. One of the handheld cams is pretty new and a bit more expensive than the other 2, as a result, that oen cam's colors are a lot more bright and vibrant than the other 2. Question is, without using color correction (my Mac won't run it...) how can I compensate and bring down the color so there's not so much of a color shift when I use the footage from that cam?
t
You can't use the simple color adjustment tools within FCP?
Chapter 27, FCP Manual?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Well that's the whole thing Terry, there are so many options, I simply do not know which one to choose...any idea?
T
Start trying different methods.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Hunt,
my question was directed more to the fact of you having SYSTEM ISSUES:
I'm taking this to understand that you can't run COLOR the application thatOriginally Posted by huntr777
comes with FC Studio? So my suggestion was just to use
the built in color adjusters in FCP as noted in Chapter 27
of the FCP manual.
And Smurfy was on the nose...
not sitting in front
of your Mac, there is only so much we can do/recommend.
But starting with the simple color adjustment tools in FCP
is a good place to start."Everyone has to learn, so that they can one day teach."
Urban Mac User
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Color Correcting in Final Cut Pro 7 (probably an easy question to answer)
By Huntr777 in forum MacReplies: 0Last Post: 18th Apr 2010, 11:49 -
Final Cut Express color grading
By DavidMaitland in forum MacReplies: 1Last Post: 9th Nov 2009, 07:50 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 10:36
