VideoHelp.com Forum
Results 1 to 10 of 10
    hi all
    i capture some videos with my sony-hdr-sr11 and LP quality
    picture is very good(1920-1080) and each hour takes about 1gb and 500mb
    the format on cam hard disk is MTS
    i do some effects an editing and cutting on the video
    the proplem is
    when i reender the video what is the best setting to use to keep same quality as the original and same size
    is it avi??
    or mpg??
    or other??
    and how can i use avi with HD setting ??
    and can some one help me how to use H264 setting???
    sorry 4 bothering but im tierd of trying and using alot of programs.....sony vegas..ulead....magix...etc
    and thaaaaaaanks alot
    waiting.............
  3. Always Watching guns1inger's Avatar
    Use mediainfo to find out exactly how your current video is compressed, and use similar settings.
    The only codec that will compete with what you have is . . . . what you have - H.264 and, maybe VC-1. H,264 can be encoded into several different containers, although some have wider support than others.
    However you will lose some quality by doing this, as you are compressing already lossy compressed footage with a lossy codec. This will, inevitably, have an impact. How noticeable it is will only be shown by trying.
    As for size, the universal equation for digital video is
    Filesize = Running Time X Bitrate
    This holds true regardless of codec, resolution or video content.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    thanks alot guns1inger
    mediainfo is a very useful tool
    i have it but gorgot to use it
    thaaaaaaanks alot
  5. Member edDV's Avatar
    Originally Posted by khalid81
    hi all
    Eye of beholder but my eyes wouldn't agree.
    You are recording at too low a rate.
    the proplem is
    First you should have recorded at a higher rate if you intend to add effects or edit on other than I frame cuts.
    Second, effects/editing will be lossy so expect a drop in quality.
    Try this project again at highest recording rate FH? and then compare the end result.
    http://www.sonystyle.com/webapp/wcs/...specifications
    http://www.kiva.org/about
  6. Member edDV's Avatar
  7. eddv i don't think the op has a clue. the spec on that cam's lowest bitrate HD setting requires about 3B/hr. the only thing he could be shooting in is standard def. long play mode at the rate he claims. either way a waste of 1920x1080 or 720x480. not nearly enough bits/sec for either.
  8. Member edDV's Avatar
    From the Sony link, there is a " LP = 22 hours and 50 min." to 60GB HDD mode at 1920x1080i or ~7Mb/s.
    This is absurd for a camcorder.
  9. hehe - almost good enough for youtube
    thanks alot guys
    i ll try to capture eith FH and then do effects and save the file
    i think this way will keep the picture with good quality
    thanks again
  1. Capture Short Video Clips From 1.5 Hour DVD
    By Grassman in forum Newbie / General discussions
    Last Post: 27th Mar 2012, 00:52
  2. JPG to 18-hour video
    By Aidan128 in forum Video Conversion
    Last Post: 18th Feb 2011, 06:21
  3. Encode DV video to play on Popcorn Hour
    By vidarmas in forum Video Conversion
    Last Post: 8th Jun 2009, 12:10
  4. It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
    By nhbfan12345 in forum Authoring (DVD)
    Last Post: 9th Dec 2008, 14:18
  5. YouTube Intros video Multi-File & 1GB Uploads
    By roma_turok in forum Latest Video News
    Last Post: 10th Dec 2007, 22:30
