I'm using dvd fab 6 and I can't backup the new transformer movie. Any ideas?
Results 1 to 18 of 18
Thread: transformers 2
Rip it4me
Movie only, should work.
Tony
It must be tuesday again
This not not an authoring issue.
Check the correct forum, DVD to DVDR, http://forum.videohelp.com/dvd-to-dvdr-f20.html, then read the big sticky at the top of the page
Next, make sure you actually have the latest version of DVDFab HD Decrypter which was released Oct 20, otherwise you may have to wait a day or two for a new update for any new copy protections.
Originally a member since 2001, LONG LIVE TARAN's!!!
Tuesday comes every 7 daysOriginally Posted by Noahtuck
However, today is Wednesday :P :P
Ahhh....Originally Posted by stiltman
But if you check the date the OP posted :P
I posted this Tuesday morning, RIPIT4ME worked. use wizard mode and your on your way
I tried ripit4me and I thougth it worked until I watched the movie, It mixed up the order of the titles. It would play like title 1, 6,9,14,2,14,7,15,11 and so on. Strangest thing I ever saw. Any Ideas?
After several futile attempts and wasted coasters using Ripit4me, I've decided to wait for the newest versions of DVDFab and DVDFabHD myself. I would get the end credits and then a missing segment from the film. These studios are getting wilier and wilier! :P
Hopefully it won't take long!
RipIt4Me
Latest version: 1.7.1.0 (March 23, 2007)
One wonders why people are still using it and then reporting problems
Stiltman,
I used the latest version and it still messed up. Try DVD shrinking it and see if you come up with better results. It does the decrypting, but I've tried it 3 times on two different pc's and it still scrambles the playback order!
You have to use AnyDVD 6.5.9.4 or Higher, Right click on AnyDVD icon, choose rip movie. Open ripped file with DVD Shrink. I used Vob Blanker before using DVD Shrink and got rid of some files. Title 47 is the good title, I think it was in VTS 9. I got the full movie. Anyway, it worked fine. AnyDVD is the way to go, forget anything else.
It Started In Texas
Look at my post again, read it VERY carefullyOriginally Posted by Hyteckman
You don't have to use AnyDVD (payware). The latest and free DVDFab HD Decrypter will do it. For movie-only decrypts, apparently this is one way to get it:
http://forum.doom9.org/showthread.ph...99#post1336499I hear this works also with ver 6.0.7.0, but I used the latest beta ver 6.1.1.8
Boot dvdfab and go into settings and then disable pathplayer.
Put the disc in and select main movie.
Find & select Title 47. MUST BE 47!
When you get errors, click "ignore all" and keep ignoring them.
Eventually, you'll get the "Next" button. Click it.
You may even get errors after it's finished & the disc ejects.
I like AnyDVD better. It looks like they anticipated a new encryption on said dvd and released an update tuesday morning. They are always on top of their stuff.
In the mean time I back it up using a Modded APEX AD-600A as player and recorded it into a DVD RECORDED(any kind), it's real time but worked great. Use A DVD+R 8.2 GB, movie last 2:32. Then using DVD Shrink make a Backup into a 4.7GB DVD-R
Just playing around with ripit4me and fixvts I was able to rip the main movie
and it played just fine as vobs 1 thru 8. The vobs themselves were sequentially correct. However trying to play it as a DVD with the IFOs it was all sequentially mixed. Strange indeed. I had posted this situation earlier re: playing the original disk on my modded firmware 5990.
With the mod, it's set up to play the movie without ever going to the menu. I hadn't seen the movie previously so after watching it for about 20 minutes and having it skip from place to place without me realizing what was happening, I was beginning to think this is one strange movie. I restarted it from the menu and it played fine.
Tony
Of course using this method you lose digital surround sound. - unless you dub to your computer using the hauppauge hd pvr 1212 and a fiber optic cable - or a soundcard with bit accurate recording like the xfi series from creative.Originally Posted by vicitacionDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Transformers
By tarzan54 in forum DVD RippingReplies: 15Last Post: 1st Oct 2011, 20:55 -
Are you going to go watch the TRANSFORMERS movie?
By yoda313 in forum PollsReplies: 24Last Post: 7th Jul 2007, 08:52
