Don't know if it's the player or the VB6ROCOD firmware or the new copy protection.
What ever it is, it took me about 20 min of watching to realize that at each chapter break
it would randomly select another chapter from somewhere else in the movie.
Pulled the disk out and put it in my PS3. Sad to say... plays fine in my PS3. I do have one 5990
that I didn't change the firware on so after the movie is over I'll try it in that one and see if
it also has the same problem.
Tony
I had a movie do the same thing a few months ago -- I don't remember which one. I'm running one of the VB6 mod firmwares too. But I the same movie wouldn't even play on another standalone player I tried. I think I ended up ripping it and watching via my HTPC.Originally Posted by cal_tony
After watching the movie on my PS3 without any problems I put the disk back in the 5990. This time instead of having it automatically begin playing without going to the menu ( a function of the VB6....firmware) I selected the menu and played it from the menu screen. This time it played normally.
Evidently, there is something with this movie that if you skip the menu selection the movie just skips around.
Tony
Windows explorer showed 8 versions of the movie in one dvd.Its got to be some new copy protection.
No. It's quite common to have multiple IFO's refer to the same VOB files, just parsed differently. I believe it's used for things like multiple angles, etc.Originally Posted by MEL15
transformers 2
By caupton50 in forum DVD RippingReplies: 17Last Post: 24th Oct 2009, 08:14 -
Best DVD Player for Playing AVI files via USB (5990 vs 5960)
By shobuddy in forum DVD & Blu-ray PlayersReplies: 16Last Post: 14th Feb 2009, 13:43 -
Philips DVP 5990 - playing JUST a single file?
By medeni73 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Sep 2008, 00:10 -
i use TSCV to make menus but i have aproblem please help me
By bite in forum Authoring (VCD/SVCD)Replies: 1Last Post: 13th Oct 2001, 08:39
