Hi --
I use the AVS video converter (I believe 6.3, but I'm not home and can't check the version#) to convert mkv files to m4v's for my iPod Touch. I know how to do the conversion and get the subs from the mkv files. My problem is that the subs always come out white, no matter what the color of the font in the mkv file.
As you all know, white subs can be lost in the background. So, what I'd like to know, is there a way to change the color of the font from the mkv file, without stripping them out?
If not, how do you strip the subs so I can do it the "hard way"![]()
I'm not always the most technically savvy, but occasionally I suprise myself, so I'm willing to try![]()
Thanks in advance!
Thread: AVS video converter
"It's more like a big ball of wibbly-wobbly, timey-wimey... stuff"
The 10th Doctor from "Blink"
Nope, this is not ADVANCED conversion. Moving you.
You must probably change font settings in avs video converter...or if it uses vsfilter while encoding you can change it in the vsfilter settings(you should then see an icon in the notification tray area).
AVS Video Converter - No audio
By Djard in forum Video ConversionReplies: 1Last Post: 21st Jul 2011, 15:49 -
AVS Video Converter
By Huh...What? in forum Video ConversionReplies: 3Last Post: 31st Jul 2010, 09:55 -
AVS Video Converter vs ConvertxtoDVD
By kuerenz in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 10:44 -
avs video converter 6 help
By Hpy68 in forum Video ConversionReplies: 3Last Post: 5th Oct 2008, 20:53 -
avs video converter
By ocko in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2008, 17:33
Statistics
Newest guides
Latest tool updates
New media comments
