I need to put the video and audio streams of an MKV file into an MP4 container. So I tried:
But, what I get is this error message:Code:$ ffmpeg -i video.mkv -vcodec copy -acodec copy video.mp4
Does ffmpeg fail putting AC3 into the MP4 container? I know, initially MP4 did not support AC3 streams, but over a year ago they officially allowed AC3 to be enclosed in an MP4 (see http://en.wikipedia.org/wiki/Compari...tainer_formats). So I expect ffmpeg to be aware of that and fulfill my wish!Code:Could not write header for output file #0 (incorrect codec parameters ?)
Do I have to to specify any parameters to pack AC3 into MP4?
Results 1 to 17 of 17
What ffmpeg version are you using? You probably need a very new build.
AC3 in an MP4 container is a recent update to the spec. As Baldrick says, you need a recent version of FFMPEG to make it happen.
"Quality is cool, but don't forget... Content is King!"
I compiled it from SVN (SVN-r20255) just three days ago:
I hope this is recent enoughCode:$ ffmpeg -version FFmpeg version SVN-r20255, Copyright (c) 2000-2009 Fabrice Bellard, et al. built on Oct 17 2009 02:49:24 with gcc 4.2.1 (Apple Inc. build 5646) configuration: --enable-pthreads --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-gpl --enable-libxvid --enable-libx264 --enable-nonfree --enable-libfaac --enable-libfaad libavutil 50. 3. 0 / 50. 3. 0 libavcodec 52.37. 0 / 52.37. 0 libavformat 52.39. 2 / 52.39. 2 libavdevice 52. 2. 0 / 52. 2. 0 libswscale 0. 7. 1 / 0. 7. 1 FFmpeg SVN-r20255 libavutil 50. 3. 0 / 50. 3. 0 libavcodec 52.37. 0 / 52.37. 0 libavformat 52.39. 2 / 52.39. 2 libavdevice 52. 2. 0 / 52. 2. 0 libswscale 0. 7. 1 / 0. 7. 1
I'd prefer to use ffmpeg :/
Here is the complete output:
Code:$ ffmpeg -i video.mkv -vcodec copy -acodec copy video.mp4 FFmpeg version SVN-r20255, Copyright (c) 2000-2009 Fabrice Bellard, et al. built on Oct 17 2009 02:49:24 with gcc 4.2.1 (Apple Inc. build 5646) configuration: --enable-pthreads --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-gpl --enable-libxvid --enable-libx264 --enable-nonfree --enable-libfaac --enable-libfaad libavutil 50. 3. 0 / 50. 3. 0 libavcodec 52.37. 0 / 52.37. 0 libavformat 52.39. 2 / 52.39. 2 libavdevice 52. 2. 0 / 52. 2. 0 libswscale 0. 7. 1 / 0. 7. 1 Seems stream 0 codec frame rate differs from container frame rate: 59.94 (60000/1001) -> 29.97 (30000/1001) Input #0, matroska, from 'video.mkv': Duration: 00:03:14.59, start: 0.000000, bitrate: N/A Stream #0.0(eng): Video: h264, yuv420p, 720x480, PAR 8:9 DAR 4:3, 29.97 tbr, 1k tbn, 59.94 tbc Stream #0.1(eng): Audio: ac3, 48000 Hz, 6 channels, s16 Stream #0.2(eng): Audio: ac3, 48000 Hz, 2 channels, s16 Stream #0.3(eng): Audio: ac3, 48000 Hz, 2 channels, s16 Stream #0.4(eng): Audio: ac3, 48000 Hz, 2 channels, s16 File 'video.mp4' already exists. Overwrite ? [y/N] y [mp4 @ 0x1076800]track 1: codec frame size is not set Output #0, mp4, to 'video.mp4': Stream #0.0(eng): Video: libx264, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=2-31, 1k tbn, 1k tbc Stream #0.1(eng): Audio: ac3, 48000 Hz, 6 channels, s16 Stream mapping: Stream #0.0 -> #0.0 Stream #0.1 -> #0.1 Could not write header for output file #0 (incorrect codec parameters ?)
Try add
-f mp4 -r 29.970 -s 720x400 -aspect 4:3
and see if it makes any difference.
Thanks for your help, but I get exactly the same error message :/
Good example for why upgrading not always is a good idea.Code:Could not write header for output file #0 (incorrect codec parameters ?)
set size according to your input file:Originally Posted by thuriel
-s 720x480
my advices will be to change audio file format (AC3 in .mp4 is not well handle by most players), prefer aac
and add a "h264 magic cleaner"
and depending on displayed errors, add some others args (like framerate, etc)Code:ffmpeg -i video.mkv -s 720x480 -vcodec copy -vbsf h264_mp4toannexb -acodec aac -ab 384k -y video.mp4
byeSome drawings ? http://www.whynotflores.com/. A software for DV, DVD-Video, HD files (AVCHD/…): http://www.movieconverter-studio.com/ 1.6 (2010/08)
Try WinFF
Thanks, Herve. I do not want to transcode the audio stream because of quality loss. And since the MP4 container officially supports AC3 I think this should be possible.
I specified the framesize and added this "magic cleaner". Still get the same error message ("Could not write header for output file #0 (incorrect codec parameters ?)"). I assume that ffmpeg is not able to process AC3 in MP4.
Even when I try to transcode my AC3 to AAC I get errors:
I guess there is only one option left: Hating ffmpeg :/Code:$ ffmpeg -i video.mkv -f mp4 -r 29.970 -s 720x480 -aspect 4:3 -vcodec copy -vbsf h264_mp4toannexb -acodec aac -ab 384k -y video.mp4 ... [NULL @ 0x1077800]error, non monotone timestamps 567 >= 300 av_interleaved_write_frame(): Error while opening file
Anyway, thanks for all your help. And, pepegot1, there is no Mac version of WinFF, but thanks anyway.
there is no concern (for FFmpeg) to wrap AC3 in mp4 (but -last time I tried- QuickTime is not able to read it for example)Originally Posted by thuriel
now the error is not the sameEven when I try to transcode my AC3 to AAC I get errors:
non continuous "displayed frames" values (should mean that your file is broken or …ended for FFmpeg)Code:[NULL @ 0x1077800]error, non monotone timestamps 567 >= 300
…are you sure that your video is not broken?Code:av_interleaved_write_frame(): Error while opening file
you could try to wrap it again with VLC (no transcode, just to wrap again audio and video, values should be continuous now)
To the best of my knowledge, only the recent versions of MP4Box and mp4creatorOriginally Posted by thuriel
support wrapping AC3 in the MP4 container. And AFAIK, only the MPC-HC MP4 splitter
is able to detect AC3 and connect it to an AC3 decoder.
Sadly the official specs do not guarantee that a feature that should be implemented
will actually be implemented. Today MP4 "officially" supports AC3, DTS, and VC-1, but...
so what?
Quite sure. Every player I used played the video fine (VLC, MPlayer and Quicktime). Besides, I get this Errors from any MKV file (I tried so far).Originally Posted by Herve
Thanks! I will try this method, when there's some time left in my busy scheduleOriginally Posted by Herve
Well, the PS3 also supports H.264/AC3 in MP4Originally Posted by El Heggunte
I wasn't aware of that. Thanks for the updated info.Originally Posted by thuriel
For info:Originally Posted by thuriel
- QuickTime first loads your mkv (slow) and build its own private index only available by QuickTime (so you don't have to care with broken files)
- VLC and Mplayer are real-time streaming softwares, so they accept broken files. They uses Presentation"timecodes"(PTS) and Display"TimeCode"(DTS) to manage to display the stream and keep synch, even if the file is not full (a hole in its middle).
But FFmepg is not a real-time streaming software, it wants continuous PTS = a valid video file
How put the subtitel in FFmpeg (pfffff)
By cane in forum ffmpegX bugs and suggestionsReplies: 12Last Post: 17th Nov 2011, 09:54 -
By cane in forum ffmpegX general discussionReplies: 1Last Post: 19th Jan 2007, 12:55 -
ffmpeg mp4 to flv
By tupanac in forum LinuxReplies: 0Last Post: 29th Oct 2006, 03:57 -
Help in transcoding Cinepak to MP4 with FFMPEG
By ClimbingAddict in forum Video ConversionReplies: 3Last Post: 23rd Feb 2006, 01:10 -
Using ffmpeg to convert .mp4 to .mov
By silsurf in forum MacReplies: 6Last Post: 6th Sep 2005, 13:57
