I can't hear audio when playing the following MKV on WDTV media player:
Video: MPEG4 Video (H264) 1280x720 23.98fps [English (Video 1)]
Audio: DTS 48000Hz 6ch [English (Audio 1)]
Subtitle: UTF-8 [English (Subtitle 1)]
The WDTV is using composite (RCA) outputs.
Is this normal?
The WDTV doesn't have the ability to down mix DTS to stereo (RCA outputs). If you plug the digital audio port into a receiver with DTS decoding you'll get audio. The new WDTV Live (aka WDTV2) has DTS down mixing to stereo.
You could use PopCorn MKV AudioConverter, which simply converts the audio in an MKV file from DTS to AC3.
It's simple enough to use, but you have to download a few small programs which it needs before you can use it.
How long does it take to convert the audio from DTS to AC3?
With a 90 min MKV, around 5 minutes or so on my system.Originally Posted by kyrcy
WDTV Live Media Player & ...
By gonwk in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2011, 18:52 -
Blu-Ray player as strong as WDTV in MKV support on DVD
By mesowetodit in forum DVD & Blu-ray PlayersReplies: 8Last Post: 23rd Sep 2010, 02:03 -
Subtitle not work with WDTV Media Player
By mmkk in forum SubtitleReplies: 4Last Post: 18th May 2010, 01:58 -
Does the wdtv media player handle dvd pal iso files?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 12th Dec 2009, 12:34 -
New NON-Blue-Ray DVD Player or better off with WDTV Live HD Network Media?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 11:36
