Results 1 to 30 of 44
  1. Member Benjy's Avatar
    How could I convert MP3 or FLAC files into AC3 and what soft are necessary ??
  2. For example...
    ... can use foobar2000 and Aften encoder.
    Or FFmpeg (possibly with some GUI), (after decode to WAV PCM) ac3enc from AC3Filter Tools, (after decode to WAV PCM - also can use Avisynth script) WAV to AC3 Encoder, BeHappy.
    VideoAudio.pl - Serwis o technologii wideo & audio
    Moving you to our audio section as I don't see what this has to do with any blu-ray.
  4. Member Benjy's Avatar
    I thought that this topic is connected with Megui , i.e. Blu-ray , a.s.o.
    10x anyway !!!
  5. Member Benjy's Avatar
    I must REPEAT my first question :
    What soft are necessary to convert WAV , MP3 or FLAC files into AC3 ???
    All the above specified softs DO NOT PROPERLY WORK and gave much , too much errors...
    There is any professional softs for this kinf of audio conversion ???
    eac3to, or avisynth + soundout are free other options
    What errors did you get with the other software? It might be issues with your source file
  7. Member Benjy's Avatar
    soundout ??? namely :......????
    except Nero 7 or Nero Hd Blu ray
    Does it be so hard, bro , to give full explanation, if you just started ???
  8. Member Benjy's Avatar
    I found a little soft : WAV to AC3 Encoder , but do not works ( gave me errors , i.e. the resulted files are empty..
    What kind of settings are necessary ???
  9. What is source audio format?
    Sampling rate is 48000 Hz?
    What is purpose of conversion?
    BTW
    In foobar2000 when convert can add DSP (Processing) and can change sampling rate used Resampler filter.
  10. Member Benjy's Avatar
    @Placio74
    Simply , I have a .wav file of 3,4 GB and I want to reduce its size at maximum and make it ac3 file.
    About foobar 2000 I'm very dissapointed because I can't setted to convert
    it is just a player , no matter how many other pluggins I installed (
    I really do not know to set it as converter(
  11. Download Aften encoder and unpack to some folder.
    File > Preferences
    Tools > Converter
    Add New > Custom
    Select a location of encoder,
    set extension as ac3,
    parameters example:
    -b 448 -readtoeof 1 -dynrng 1 -v 0 - %d
    complete display info.
    (-b 448 it's just bitrate - can set other.)
    Add file in player,
    right mouse button (context menu) on file,
    Convert..., choose (previously created) output format,
    if want resample, go to Processing tab, turn on DSP, add Resampler, set 48000 Hz in configuration,
    finally click OK.
  12. Member Benjy's Avatar
    @Placio74
    Many thanks...I already had Aften but I didn't know to set it...
    There is another problem , a little one : what about that < lame.exe> ??
    I don't know where to place it or to find it or how to set it....also , It seems that didn't setted for AC3 , but for mp3 and I do not want mp3...
    If you wanted to use eac3to, it's a simple 1 commandline:
    eac3to input.wav output.ac3
    http://en.wikibooks.org/wiki/Eac3to/How_to_Use
    There is a gui to use it, but you have to set it up properly
    For avisynth, you would input your source filter, and just type soundout(). When you open the script in a media player or avsp it will give you encoding options. You need avisynth installed and soundout in your plugins directory
    The script is just a notepad text file. You save it and rename the extension to .avs.
    e.g.
    WAVSource("myaudio.wav")
    Soundout()
    For foobar 2k, just right click and select convert
  14. Originally Posted by Benjy
    Just click on ... button and select location of encoder.
  15. Member Benjy's Avatar
    I see...that is the problem (
    In my folder where is foobar 2000 and should be that < lame.exe> , this is...absent
    I haven't it (
    Maybe the soft I find and installed was incomplete(
    No problem I will give up ,coz is too difficult for me , and everybody explain to me briefly ,like I 'll be an expert....
    I found out on webs half a day and all I found was that stupid soft which seems to be incomplete (
    Thanks anyway for your help !!
    PS I think this foobar 2000 is not good for what I need : I want a file of 1,5 GB , format .wav to convert to a little one , format ac3...that's all...this foobar converts to mp3 , which is totally different
  16. Originally Posted by Benjy
    I haven't it (
    Wrong.
    Look again at screenshots (just download and set other encoder - Aften for AC3)
    foobar2000 does not contain any encoders (need download them separately), but has several predefined profiles - also user can make new own (custom) profiles.
    Try WinFF (FFmpeg GUI).
    Convert To... = Audio
    Device Preset = Ac3 DVD
    Also can click at Options and set own bitrate...
  17. Member Benjy's Avatar
    @ Placio74
    Asd I told you I'm a noobye , I don't know what bitrate to set and so on..
    can you show me , for exemple ???
  18. Member Benjy's Avatar
    I'm back...unfortunatelly I installed ALL soft you have recomanded me , but there is NO such a < lame.exe> and NO possibility to convert from .wav to .ac3...
    Are you really good at this problem or talk by the ear and laugh with me???
    Are you joking with me ?
  19. Originally Posted by Benjy
    Lower bitrate = worse quality but smaller file.
    Higher bitrate = better quality but larger files.
    http://en.wikipedia.org/wiki/Bit_rat..._in_multimedia
    If you still want to try with foobar2000...
    Download Aften encoder from here or here or here.
    Unpack to some folder and when create new custom profile select path to aften.exe file.
    If aften.exe file is in foobar2000 folder, enough just type aften.exe instead whole path.
    Do you really tried to use WinFF?
  20. Member Benjy's Avatar
    Now I tried winff....it requires any supplementary settings or patches ???
    'coz gaves me errors...
  21. Originally Posted by Benjy
    No.
    Specifically what errors?
    What are characteristics of source audio file?
    Use MediaInfo, export info to text file, show here content.
    Can play source audio file?
    BTW
    Initial question was: "How could I convert MP3 or FLAC files into AC3 and what soft are necessary?".
    However, later you said about WAV file...
    Why not convert directly - MP3>AC3 or FLAC>AC3?
  22. Member Benjy's Avatar
    Format : Wave
    File size : 3.93 GiB
    Duration : 1h 1mn
    Overall bit rate : 9 216 Kbps
    Audio
    Format : PCM
    Codec ID : FFFE
    Codec ID/Info : Extensible
    Duration : 1h 1mn
    Bit rate mode : Constant
    Bit rate : 9 216 Kbps
    Channel(s) : 8 channels
    Channel positions : Front: L, C, R, Middle: L, R, Surround: L, R, LFE
    Sampling rate : 48.0 KHz
    Resolution : 24 bits
    Stream size : 3.93 GiB (100%)
    PS Sorry ,it was my mistake regarding that mp3...wav to ac3 is true...
  23. Uh... 8 channels. It's problematic - need downmix. Unfortunately, it's rather not easy.
  24. Member Benjy's Avatar
    It's not necessary 8 channels , just 2 if it is possible...
    My great problem is to resize it from 3,9 GB to a " human " size , let's say about 300 Mb....
    This is an audio track from a movie , I have split it , mean time I encoded that movie from 1980 to 1280 and now I want to menage audio track , but as you can see , now the audio track is bigger than the whole movie )
  25. Try BeHappy...
    - install Avisynth
    - download and unpack BeHappy
    - download Aften and copy aften.exe to encoder subfolder in BeHappy
    - choose Avisynth plugin to use - WavSource, RaWav or DirectShowSource
    - choose source audio file
    - set Downmix
    - choose destination and encoder (can change configuration)
    - click on Enqueue button
    - go to Queue tab and click Start button
    BTW
    foobar2000 - does not support decoding 8 channel WAV files
    FFmpeg - can't downmix (8 channels is not accepted for ordinary AC-3 audio)
  26. Member Benjy's Avatar
    ok
  27. Member Benjy's Avatar
    I think , after many tryings , I solved smth , but not too much..
    Here is the error it gave me :
    BeHappy.AviSynthException: Import: unable to read "C:\Documents and Settings\EMPEROR\Desktop\sound.wav"
    at BeHappy.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace, AviSynthScriptEnvironment env)
    at BeHappy.Encoder.encode()
    What does it means ???
  28. Odd... maybe move file to other folder.
  29. Member Benjy's Avatar
    which one...the original or the resulted one ???
    I think is a problem of settings...coz the second time , it gave me another kind of error after I modified some settings....
    Unfortunatelly I do not know how to set it normally and correct (
    what you've showed me above is not enough....
  30. Member Benjy's Avatar
    Here is few screenshots...
  1. Replies: 7
    Last Post: 12th Dec 2009, 11:12
  2. flac to mp3
    By angryassdrummer in forum Audio
    Last Post: 7th May 2009, 05:18
  3. Flac Files To MP3 Which Software??
    By Lennoxtown in forum Audio
    Last Post: 9th Sep 2007, 07:22
  4. MP3 vs FLAC
    By lordhutt in forum Audio
    Last Post: 3rd Mar 2007, 13:57
  5. Burning mp3/FLAC
    By rjc7394 in forum Audio
    Last Post: 26th Oct 2005, 15:00
About   Advertise   Forum   RSS Feeds   Statistics   Tools
