Have been capturing some old video tapes. Problem I have had is that the incoming audio has been a little too low for my liking. I have been ripping the audio off the video and using some audio editing software to improve the volume, and although it is satisfactory, I am not really getting the results I would like.
Just want to know if there is anyway I can increase the volume of the source while I am capturing?
Also, what would be the best audio editing software for improving the clips volume?
Thanks.
If your capture software has recording volume settings you can use that. If it's maxed out already, and the source is just too low, you can use an amp between the source and capture card. Otherwise you'll have to adjust the volume after capturing. For best quality save the audio uncompressed while capturing, compress after adjusting the volume.
There is one special case: mp3 audio. The volume can be adjusted without reencoding. There's a thread or guide around here somewhere about it. You're still better off capturing uncompressed, adjusting the volume, and encoding later though.
Audacity is a good freebie to work on audio files.Originally Posted by gmania
You demux and use the audio file in Audacity, do you thing, normalize and increase volume for example, (can save as AC3 file if you wish) then mux back and author and burn to DVD.
how to increase the volume of the audio?
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 06:45 -
Increase Audio Volume?
By ambrosechapel in forum ffmpegX general discussionReplies: 6Last Post: 7th Nov 2007, 09:05 -
How to increase capturing volume using pinnacle sofware?
By method in forum CapturingReplies: 0Last Post: 20th Jan 2007, 05:25 -
ac3 help with audio increase the volume
By MEANGUNS in forum Newbie / General discussionsReplies: 4Last Post: 4th Mar 2005, 22:44 -
How to Increase audio volume?
By siaododo in forum DVD RippingReplies: 2Last Post: 3rd Dec 2001, 17:25
Statistics
Newest guides
Latest tool updates
New media comments
