Imutube hd this script encode video to hd
use 1 pictures + 1 song...
but in now how i can make it on multi-pictures.
can any one give script multi-pictures (10 or 20 30..... pictures+ 1)
this script Imutube HD.
Code:@echo off color 0d :check_avisynth dir "%ProgramFiles%" | find /I /C "avisynth" > tmp set /P str=<tmp && del tmp && cls IF %ERRORLEVEL% NEQ 0 set str=0 if %str% GEQ 1 goto check_avisynth_end dir "%ProgramFiles(x86)%" | find /I /C "avisynth" > tmp set /P str=<tmp && del tmp && cls if %str% GEQ 1 goto check_avisynth_end echo Are you sure you have AviSynth installed? Avisynth is required echo for the script to work properly. Get it at http://avisynth.org echo. echo You can press any key if you wish to continue, echo but be warned that things might not work as they should =D echo. pause > NUL :check_avisynth_end cd /d %~dp0 :source_check if NOT EXIST "%~f1" goto source_fail if NOT EXIST "%~f2" goto source_fail if /I [%~x1] == [.mp3] (set sourcea=1) else (if /I [%~x2] == [.mp3] set sourcea=2) if /I [%~x1] == [.aac] (set sourcea=1) else (if /I [%~x2] == [.aac] set sourcea=2) if /I [%~x1] == [.m4a] (set sourcea=1) else (if /I [%~x2] == [.m4a] set sourcea=2) if /I [%~x1] == [.jpg] (set sourcev=1) else (if /I [%~x2] == [.jpg] set sourcev=2) if /I [%~x1] == [.png] (set sourcev=1) else (if /I [%~x2] == [.png] set sourcev=2) if /I [%~x1] == [.bmp] (set sourcev=1) else (if /I [%~x2] == [.bmp] set sourcev=2) if [%sourcea%] == [] goto source_fail if [%sourcev%] == [] goto source_fail goto source_pass :source_fail cls echo I didn't get the input files! Select both audio and picture echo and then drag-n-drop it into the script file at the same time. echo. echo Supported input files: echo Photo: JPG/PNG/BMP echo Audio: MP3/AAC echo. echo. pause goto end :source_pass echo Working... echo. :variables if [%sourcea%]==[1] ( set m1="%~n1" && set m2="%~n2" ) ELSE ( set m1="%~n2" && set m2="%~n1" ) if [%sourcea%]==[1] ( set output="%~n1 (MicroHD).mkv" ) ELSE ( set output="%~n2 (MicroHD).mkv" ) if [%sourcea%]==[1] ( set sourcea="%~f1" ) ELSE ( set sourcea="%~f2" ) if [%sourcev%]==[1] ( set sourcev="%~f1" ) ELSE ( set sourcev="%~f2" ) set m1=%m1: =% set m1=%m1:-=% set m1=%m1:_=% set m1=%m1:.=% set m1=%m1:&=% set m1=%m1:(=% set m1=%m1:)=% set m1=%m1:"=% set m1=%m1:'=% set m2=%m2: =% set m2=%m2:-=% set m2=%m2:_=% set m2=%m2:.=% set m2=%m2:&=% set m2=%m2:(=% set m2=%m2:)=% set m2=%m2:"=% set m2=%m2:'=% set m1=%m1:~0,24% set m2=%m2:~0,24% set m=immd-%m1%-%m2% :resolution_check tools\MediaInfo --Inform=Image;%%Width%% %sourcev% > %m% set /P width=<%m%&& del %m% tools\MediaInfo --Inform=Image;%%Height%% %sourcev% > %m% set /P height=<%m%&& del %m% set resolution=%width%x%height% if %resolution%==1280x720 goto resolution_pass if %resolution%==960x720 goto resolution_pass cls echo Your source picture is not 1280x720 (its %resolution%), echo and thats not recommended. Youtube HD works best with 1280x720. echo. echo Enter "y" (or hit Enter) to resize to 1280x720 on the fly, or echo enter "n" if you still insist on continuing without resizing... echo. set /p resize=Auto resize to 1280x720 [y]? IF %ERRORLEVEL% NEQ 0 set resize=y if %resize%==n goto resolution_pass set width=1280 set height=720 :resolution_pass :make_avs echo ImageSource(%sourcev%, end = 19800, fps=30).LanczosResize(%width%,%height%).ConvertToYV12() > %m%.avs :variables_frames tools\MediaInfo --Inform=General;%%Duration%% %sourcea% > %m% set /p frames=<%m%&& del %m% set /a frames=%frames% * 30 / 1000 :variables_keyint set keyint=300 :variables_cats set /a cats=%frames%/%keyint% :encode_slice tools\x264 --fps 30 --frames %keyint% --keyint %keyint% --qp 20 --8x8dct --me umh --threads auto --thread-input --progress --no-dct-decimate --no-psnr --no-ssim --output %m%.mp4 %m%.avs del %m%.avs :bad_avs FOR /F %%A IN ("%m%.mp4") DO IF %%~zA EQU 0 goto bad_avs_error goto bad_avs_end :bad_avs_error del %m%.mp4 cls echo Error: Couldn't encode to x264. echo. echo Please try using only alpha-numeric (a-z, 0-9) characters in source filename. echo AVISynth has issues with some symbols and non-english characters. echo. pause goto end :bad_avs_end set mp4=%m%.mp4 set bat=%m%.bat if %cats% GEQ 100 goto box_script2 :box_script set i=1 set /a x=%cats% echo tools\box %mp4% ^^> %bat% :loop if %i%==%x% goto loop_end echo -cat %mp4% ^^>> %bat% set /a i=%i%+1 goto loop :loop_end echo -cat %mp4%>> %bat% call %bat% :box_script_end del %bat% goto mux :box_script2 set i=1 set /a x=100 echo tools\box %mp4% ^^> %bat% :loop2 if %i%==%x% goto loop_end2 echo -cat %mp4% ^^>> %bat% set /a i=%i%+1 goto loop2 :loop_end2 echo -cat %mp4%>> %bat% call %bat% set /a cats=%cats%/100 + 1 :box_script3 set i=1 set /a x=%cats%-1 echo tools\box %mp4% ^^> %bat% :loop3 if %i%==%x% goto loop_end3 echo -cat %mp4% ^^>> %bat% set /a i=%i%+1 goto loop3 :loop_end3 echo -cat %mp4%>> %bat% call %bat% :box_script2_end del %bat% goto mux :mux tools\ffmpeg -i %sourcea% -acodec copy -i %m%.mp4 -vcodec copy %output% -shortest del %m%.mp4 :end
Results 1 to 1 of 1
Thread: IMutube HD Multi-Pictures
Hello to evry one
Multi-Audio Stream to Multi Device Happiness
By ebobster in forum Video ConversionReplies: 0Last Post: 15th Nov 2011, 01:18 -
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 14:21 -
Multi-monitor, multi-video feeds
By Robert Hedderman in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 13:21 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
