My LCD screen is always white! Any ideas what can be the problem?
THANKS!
Thread: SAMSUNG camera LCD white screen
Can you get picture in the viewfinder?
If so, my guess is the LCD has a detached or shorted cable.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Yes, I have picture in viewfinder. I think so that the cable is a problem. Can be anything other the problem?
All you can do is wiggle it from the outside. A local camcorder repair shop should be able to fix it and cheaper than "factory service" flat rates.Originally Posted by szalaikornel
It could be a failed module but that is less likely than a connector issue.
Camcorders are difficult to self service. You may do more damage.Recommends: Kiva.org - Loans that change lives.
Check your owner's manual. In low-light settings, many camcorders have a feature that turn the flip-out screen into a type of light to better illuminate the shot. (Of course, the screen should be rotated toward the subject in that case.) I don't know about your particular model, but I'm guessing it is set as a light instead of a view screen.
LCD only has white screen with sound.
By tj1182 in forum DVB / HDTVReplies: 1Last Post: 20th Jan 2010, 20:21 -
PC to Samsung LCD Again
By southcraven in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2009, 21:15 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
lcd screen is just "white" blank when booting up
By edong in forum ComputerReplies: 3Last Post: 3rd Jul 2008, 02:02 -
LCD TV completely white screen (no sound or anything)
By evanwils in forum DVB / HDTVReplies: 4Last Post: 5th Nov 2006, 21:57
