Hello,
I wanted to know if there are any particular settings for XViD to make it compatible with PS3, XBOX360 and other gaming consoles. They sometimes work fine, but most times they don't.
I use meGUI and I have Qpel and GMC unticked. What else needs to be set?
Thanks!
No packed b-frames, no VBR MP3 audio.
This is why I use AutoGK for most Xvid output. It already takes all this into account.
You mean no packed bitstream? Could you please use meGUI specific options?
Here are my settings:
The Divx Home Theater profile uses single B frames and Packed Bitstream. I suspect the PS3 and Xbox 360 supports that. Do a few quick tests and see. Try the "Xvid: 2pass HQ (Home Theater)" profile in MeGUI.
Don't enable GMC or QPel.
The Home Theater profile has DX50 instead of XviD. What's so special in DX50 as the FourCC? Is that the element making it player compatible?
Probably not. DX50 is the fourcc for Divx 5.0. Divx 6 and 7 also use that fourcc because they are backwards compatible with Divx 5.0 decoding. XVID is the fourcc used by the Xvid encoder by default. But they are both MPEG 4 part 2 codecs. Differences between them are pretty minor. There are a few players that will accept only one or the other fourcc. You can usually use a fourcc changer to change the fourcc if that's the case.Originally Posted by blackflames
I am not sure what the case is. I will use the Home Theater profile to see if it works.
You can force the fourcc in xvid using the supplied pulldown.
Xvid, Max B-frames for PS3 & Xbox 360
By duff916 in forum Blu-ray RippingReplies: 3Last Post: 15th Jan 2012, 20:13 -
H264 to MP4 for PS3 or XBOX360
By DVDONE in forum Video ConversionReplies: 4Last Post: 27th Mar 2010, 15:07 -
on/off subtitles for both PS3 & XBOX360?
By Randm in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 04:11 -
Steam DVd folders from PC to Ps3/xbox360
By pcexpress911 in forum Media Center PC / MediaCentersReplies: 20Last Post: 13th Feb 2009, 03:10 -
XBOX360 PS3 - HDMI Full HD Capturing
By TermiATT in forum CapturingReplies: 6Last Post: 12th Jul 2008, 21:59
