Version 3.0.0100
I tried to extract the first chapter of a title by making sure it was the only one ticked but the program continued on to extracting chapter 2. When I pressed the cancel button the program aborted the chapter 2 extraction and then continued to remove the redundant audio stream from chapter 1. The end result was what I wanted but clearly the program has a bug in the process.
M. R. Murry
Can you post your log file please of this run?
I see what it's attempting to do. It's trying to join the VOB-set into a single VOB file before extracting the required chapter. Cancelling then causes it to skip and use the partial VOB file created by the aborted first step. A very inefficient approach, don't you think?
I don't have the log files to hand and, frankly, I'm not that bothered - I've given up using this software. In the VERY short time I've been using it I have found it far too problematic. Even after buying the Pro version, the performance is still rubbish compared to a lot of the alternatives (probably related to the above issue), that and not being able to rely on it to correctly extract the default audio stream if there is more than one (also reported by several other users on this forum) and the fact that the resulting file size is somewhat questionable (I opened the finished MPG in Womble Video Editor, added 2 seconds of blank screen to the start and confirmed that there would be no re-encoding but the new MPG was considerably smaller!) all make it a bit of a waste of money and, more importantly, a waste of my time.M. R. Murry
DVD Disc Chapter Extraction For .mkv?
By Mucx in forum MacReplies: 3Last Post: 9th Aug 2009, 15:13 -
Specific Chapter Extraction w/ MTR
By Telakenisis in forum MacReplies: 11Last Post: 14th Jun 2006, 13:59 -
chapter extraction....and reauthoring
By St.Thanos in forum Newbie / General discussionsReplies: 0Last Post: 26th Apr 2004, 16:53 -
Chapter Extraction(ripping?!?) from DVD
By aftergard in forum Newbie / General discussionsReplies: 3Last Post: 21st Aug 2003, 12:07 -
DVD Chapter extraction to SVCD - How??
By MNale in forum DVD RippingReplies: 1Last Post: 5th Nov 2001, 16:43
Statistics
Newest guides
Latest tool updates
New media comments
