VideoHelp.com Forum
Page 2 of 2
FirstFirst 1 2
Results 31 to 49 of 49
  1. Hi Penny;
    So - now I read your e-mail exactly........
    [QUOTE=winapenny;2035483]
    Originally Posted by Pikey View Post
    Grateful if you could share more details:
    1. What Ubuntu version you were using; 7.10
    2. How to you "mount" the DVDR3455H hard disk (command line or Disk Utility);Using Ubuntu's own "mount disk" option
    3. What kind of file system did you recognized; Don't remember - but it wasn't DOS or Linux.
    4. How is the video files you "copied" looks like? Readily playable in your Windows PC? No - I tried and Ubuntu wouldn't play them and nor would windows. They went onto the new disk in the DVD recorder and then I downloaded them as usual.
    Many many thanks! De Nada!
    Penny
  2. I've tried to do similar, put the drive into Ubuntu, and mount it but there is no valid partition table so no partitions to mount.
  3. Member bithead9's Avatar
    Is this a liteon clone? If so there is a HDD hack to expand the supported hard drive size to 512GB.
  4. Its fairly easy to upgrade the internal drive, just replace with another larger IDE drive, burn a cd with the latest firmware from the phillips website burnt as in the instructions they give, then once the firmware had been loaded go into the dvd player menu and erase the drive which formats it in its own native format. I've got a 320GB drive in mine now. Unless you mean theres a hack to expand to a larger drive but keeping the existing data? If so can you provide a link to it? I've got the original drive and spare IDE drives around so happy to give it a go and report back.
  5. Member bithead9's Avatar
    Cool. I know some mfg. limit the drive size according to the model you bought. Liteon and Philips have both done this. But the Philips one was aliteon clone... The Ilo is another, and the Gateway. There are a few more too.... Glad it was so easy for you. Does a SCANDISK (if that exists in your unit) not cause any problem with larger drive ? And do you get all the space of a new bigger HDD too? f so that is great!
    Hello,
    i have one problem. My hard drive burned out. now i'm trying to exchange it to new one but i have one problem. I can't find FIRMWARE to my PHILIPS DVDR 3360H anywhere :/
    Anyone hae any idea where i can find it?
  7. Member dphirschler's Avatar
    I think I found your firmware here (on Philips' website).
    http://www.p4c.philips.com/cgi-bin/d...&scy=AT&slg=en
    Check the model number carefully. It appears there are two variants. I had to choose Austria for the country.
    Darryl
    Thank You.
    But there is Firmware upgrade not just firmware. Is it the same?
    I'll try tommorow and we'll see..
  9. Member dphirschler's Avatar
    Originally Posted by allskar View Post
    Thank You.
    It's the same. A firmware upgrade might be an improved version of the stock firmware. Compare the version numbers. Usually, the newer firmware improves performance and removed bugs. But if you need to get the original firmware, that could be difficult unless it is on Philips' website as well.
    Darryl
    Thank You!
    I work's i was close to put it to the garbage
    So for sure it works also for DVDR 3360H
    I came across this thread hunting for possible fixes for my 3345. It had been working just fine - all functions. A surge or something came down the wire that messed up the power board on my plasma (thank God for extended warranty plans!) and messed up the cable box. so, I had the TV fixed and called cable to deal with the box. I didn't take note of the HDR until some time later. It has no video output other than a white screen with a black vertical line. The front display is very dim, almost illegible. The DVD drive opens and spins, the harddisc spins, the cooling fan runs. I'm pretty handy so replacing boards is a piece of cake - if I know which board to replace and where to get it.
    Anybody got any clues? Thanks!
  12. Member dphirschler's Avatar
    If I had to guess, I'd say the power supply got fried. Most likely it's a separate board, but I do not remember.
    Darryl
    A Philips disk format can be copied to another disk in Windows (or any other OS as disc is bootable) by using
    Easeus disk copy. Download the ISO file and burn to a CD. This CD is bootable. Boot into Easeus and follow instructions for copy disk. The Philips original disk, of course, must be OK in its machine. On the new disk the format will be overwritten. Whatever format, or not, doesn't appear to matter on the new disk. Disk copy recognises Usb so both disks can be put into Usb caddies.
    You can probably abort copy disk around 2Gb (Poss 1GB) as 80Gb takes about 2hrs. I have done both and actually the 2Gb copy loaded easier into machine, the 80Gb messed me about.
    My machine is a 3300H but I assume same format on all later Philips.
  14. Member bithead9's Avatar
    I'd say crack that unit open and post us a picture of the innards. The power supply may have protection diodes. If so you will see a burn mark or if you are handy with an ohm meter you can check for continuity. It really does sound like a fried power supply board. Some voltages I guess are getting thru (white vieo you describe). But not all are correct. Maybe the 5V line is hosed.
    Hi,
    I followed the instructions posted by dphirschler: I formatted the WD HD [the original 160GB that came with the player] using Swissknife once, but after that I tried using WD Format utility (FAT 32). Then I used the Upgrade code available from the philips site. (upgrade code for DVDR3455H/97). However, as soon as the upgrade is complete, the player/ recorder reboots and actually keeps on rebooting....
    I seem to reach nowhere...
    Any help is appreciated!
    Thanks,
    tech-guy
  16. Member bithead9's Avatar
    What happens if you boot the unit with NO hard drive ? Do you at least get an error message ? If it does a continual reboot after removing the HDD you have a bigger problem. Again I will say that perhaps a picture or two may help in diagnosis. The higher the resolution the better. (especially of the power supply area of the main board). I presume you also tried to NOT format the drive and let the Philips try to do that at startup? Most of these units will handle formatting the hard drive. If you have the firmware maybe you need a patch for bigger hdd ? Is this a liteon clone? I am no tfamiliar with ths particular unit.
    Hello,
    At last and after several attemps, I managed to get my philips DVDR3455H/97 to work with my original HDD (160GB).
    Thanks to the guys in this forum and other forums.
    Problem Description:
    DVDR keeps on rebooting and rebooting moving between HDD and DVD. So, what I did is Low level formatted HDD, then completely formatted it with NTFS (since the low level format was made in FAT32). I used the code availablein Philips website (the upgrade code). I inserted the upgrade CD in the dvd tray, powered up the recorder, it wen through the normal sequence of copy/load/boot/write/verify/boot and the DVDR was finally recovered!
    Of course, since the upgrade code I used is meant for US based devices, I had to change the region code from 3 to suitable one for my region. After that, the player is able to play any DVD.
    However, I now have a different problem!
    The player does not record anything on HDD, whether this was time shift buffer recording or actual recording (REC).
    This is really strange and funny at the same time!... A DVD recorder that does not record!
    Appreciate any help!
    Thanks,
    tech-guy
  18. Member
    Hello again!
    Looks like I solved the problem related to recording and just now!
    It runs out that you got to go the SETUP, to the settings for the TIME SHIFT BUFFER and erase the Hard Disk completely. This will reformat the HDD and let the player recognize it in its own format, the one suitable for all kinds of recording.
    Now, I have a completely running DVDR.
    Good luck to everyone,
    tech-guy
  19. Member bithead9's Avatar
    Well done. Glad you got it going! Documented for posterity on this thread. SO tell me is the HDD you low level formatted the ORIGINAL HDD or a NEW Wester Digital that you mentioned ? I am wondering if you can put a bigger HDD in there and do the ERASE just the same ?
  1. Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
    By Roberht in forum DVD & Blu-ray Recorders
    Last Post: 11th Feb 2012, 12:37
  2. Philips DVDR-3480 DVD Recorder and Player 1080i‏
    By Vixfoxwatch in forum Newbie / General discussions
    Last Post: 7th Nov 2010, 14:18
  3. Philips DVDR 3455H and DishNetwork DVR 625
    By mdtx001 in forum DVD & Blu-ray Recorders
    Last Post: 14th Oct 2010, 17:57
  4. philips dvdr 3455h
    By mikes94547 in forum DVD & Blu-ray Recorders
    Last Post: 24th Dec 2008, 09:36
  5. Philips DVD 160GB Recorder Model DVDR 3455H
    By vsenapati in forum DVD & Blu-ray Recorders
    Last Post: 28th Jun 2007, 19:56
