VideoHelp.com Forum
Results 1 to 9 of 9
    Hello,
    since some weeks, I've been wondering about buying the (in)famous LG BE06LU10 Blu-ray recorder.
    In short, what I want to do is to make backup copies of NON protected disks.
    But, mainly because a BD-50 costs the impossible, I'd really be glad if there was a method to shrink a BD-50 into a BD-25.
    Hence my question: are there any 100% working methods for doing this?
    I don't wanna waste my money in buying a recorder with which I wouldn't be able to do what I want to do...
  2. Mod Neophyte Super Moderator redwudz's Avatar
    With BDs, nothing is 100% working. But BDRebuilder is popular for 'shrinking' BDs down. I would also recommend using ImgBurn to burn the BD discs.
    And welcome to our forums.
    Yep, I know BDRebuilder.
    My main issue is that my parents are giving the money for the BE06LU10, and they want to be 100% sure that the Blu-ray copies will work.
    DVDFab's team is gonna release an utility for shrinking BD-50 to BD-25, hope this will work...
  4. Mod Neophyte Super Moderator redwudz's Avatar
    With many BDs, the main movie, without subs and additional languages, will fit on a BD-25 disc with no conversion. You just need a decrypted BD file and ImgBurn. I use tsMuxeR to remove the extra stuff.
    Another issue is playback. If you want to use a standalone player, a set top player, you need to find out what formats they will accept. Not all accept burned BD-25 discs.
    DVDFab's offering sounds interesting. I use AnyDVD for decryption and it hasn't failed me yet. But some BDs have odd structures and are fairly difficult to convert/backup.
    Do you have to use a external burner/reader? It seems like an internal one would be cheaper and more reliable.
    And be aware that 'shrinking' a BD takes a lot of CPU power and a fair amount of storage space and time. My BD>MKV backups to 8.5GB MKV's with RipBot take about 6 hours, and that's on a 3.4Ghz quad core PC. I don't have a set top BD player, so I don't need that format.
    Received.
    Well, I have a hyper-threading Pentium IV 3.0 GHz with Windows XP SP2 installed.
    I'm writing in this thread with my MacBook Pro 2.16 GHz - but, just to make things clearer, my MBP would NOT be used for decrypting and encoding Bluray disks.
    This would be my combo:
    - LG BE06LU10 Blu-ray external burner (external is needed, 'coz I'm gonna use it both with my MBP and my PC)
    - SHARP (Aquos) Blu-ray player - and yes, it DOES support BD-R and BD-RE. Haven't checked BD-R DL compatibility, but - since a BD-R DL costs 25 Euro, BD-ROM DL to BD-R DL is not my priority
    Total cost: 320 Euro ca.
    I'm blocked, although. Before buying all this stuff I have to be sure that, if not 100%, it would work at least by a 85-90% of the cases. As I repeated before, that's because my parents are giving me the money. If I was able to decide, I'd have bought all many months ago
    Originally Posted by Tyrexionibus
    Received.
    encoding blu rays @ highest settings w/ BD Rebuilder on a P4 will take days
    ocgw
    peace
    Athlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
    http://forum.videohelp.com/topic368691.html
  7. Member fritzi93's Avatar
    No kidding. :P You need a dual core at minimum.
    Pull! Bang! Darn!
  8. Mr. Computer Geek dannyboy48888's Avatar
    http://forum.videohelp.com/topic368143.html#1987253
    works great for 99% of videos out there
    enjoy
    if all else fails read the damn manual
    No lie, my dual core 3ghz would take approx 12-18 hours, sometimes a full day on those big movies. My newer quad core is around 6-8 hours. I wouldn't even bother on the slower processors.
  1. Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
    By brad350 in forum Newbie / General discussions
    Last Post: 21st Apr 2012, 04:15
  2. M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
    By messi magician in forum Authoring (Blu-ray)
    Last Post: 15th Jan 2012, 18:25
  3. DVDFAB Blu ray to blu ray free version stopped working
    By kohlirowe in forum Blu-ray Ripping
    Last Post: 5th Jul 2010, 10:50
  4. Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
    By rayinblu in forum Newbie / General discussions
    Last Post: 15th Apr 2010, 09:37
  5. Replies: 5
    Last Post: 5th May 2008, 16:05
