Unless it was "Security is nothing...if someone is motivated enough to get it, they will..." which was clear enough.Originally Posted by Video Head
The rest of the story didn't make much sense to me though, which is what I commented on.
Results 31 to 35 of 35
there are no legitimate users unless i allow them and the ones who can't figure it out by themselves i can hook up. most of the time no one is logged on the wifi. with no one on, it doesn't transmit anything, all it does is listen. i admit if there were traffic, it may not take long to find it. but, then they'd have to get through the other protections. my logs don't show any users i didn't allow.You didn't try Kismet, did you?
Here's a tutorial to get you started: http://www.wi-fiplanet.com/tutorials...le.php/3595531
It would take a "determined hacker" two minutes.
You gain nothing over simply using a strong WPA password.
You can hide from people who aren't a threat anyway -- as you say, all you've done is make it hard for legitimate users to log on.
Exactly. It was not meant to make sense to you. You live in Hong Kong. You do not have a vehicle. The analogy was intended to be foreign. As is setting-up the security on a residential wireless router to the OP. We were mearly providing the OP with the knowledge necessary to configure a reasonable level of security. You brought forth no solutions, just cynical criticism.Originally Posted by AlanHK
Good day.
Still not getting your point: "It was meant to be foreign"?Originally Posted by Video Head
And while not at having a car here, the concept is not "foreign" to me. Just your story had no basis in reality.
I suggest just saying what you mean rather than giving extended fables.
And as for the pompous "We were mearly providing the OP with the knowledge.... You brought forth no solutions, just cynical criticism", well, not true and offensive. I said that a good WPA password was a more than reasonable level of security, while pointing out that messing around with the SSID is just a waste of time, causing hassles to normal software, while not impeding hackers. Sorry if hearing that damages anyone's self esteem.
Actually, in security matters, you really should cultivate a cynical and critical frame of mind.
Well, the security on my home setup is actually crappy, a very old 802.11b access point that only has WEP. But it's semi-rural, I only have two or three neighbours in range and know them personally.Originally Posted by minidv2dvd
I just turn off the access point except when I'm running a laptop.
Though I'm pretty sure that a hacker couldn't get into my router via wifi.
I would upgrade and harden this if I was, say on a main street or a campus.
I know the risks I'm running, I just wanted to be sure you did.
AACS Bluray encryption
By BIFFtheSTIFF in forum MacReplies: 0Last Post: 17th Jun 2011, 21:26 -
Does GI Joe: Rise of the Cobra use a new encryption...
By rayden54 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Apr 2010, 10:45 -
Best encryption algorithm?
By alegator in forum ComputerReplies: 5Last Post: 10th May 2009, 23:37 -
BD+ encryption blue-ray
By herbapou in forum Blu-ray RippingReplies: 4Last Post: 24th Mar 2009, 07:58 -
how to use WPA wireless protection?
By Rudyard in forum ComputerReplies: 7Last Post: 5th Mar 2009, 16:19
