VideoHelp.com Forum
Results 1 to 30 of 34
    Those dvd rips found on the net, 272 pixels tall, are no mystery for me... I guess they are deinterlaced PAL dvds. But what about 384 pixels? Some dvd rippers release these files on the net, and it doesn't seem it's possible to achieve the same quality by any deinterlacing process.
    Any clue of how these rips are made?
  2. Banned
    What a video's resolution has to do with deinterlacing?
    512x384 is a perfect 4:3 res
    682x384 is a near match for 16:9 res
    If the source is DVD-Video or BD obviously they were resized
  3. Member edDV's Avatar
    See What is DVD?
    http://www.videohelp.com/dvd
    "NTSC" progressive would be 720x480p @ 23.976 fps
    "PAL" progressive would usually be 720x576 either P or i @25fps
    http://www.kiva.org/about
    From the tests I runned I could notice that the best quality is achieved by excluding one field. Through all the other deinterlacing methods, the picture gets blurry. And those 384 pixels videos have a pretty sharp picture, as though they were ripped directly from the 24 fps theatrical film.
    edDV,
    my question is whether the movie industry releases these progressive DVDs. I have only seen 29,97fps interlaced so far.
    Thanks!
    Most NTSC movie DVDs are encoded progressive with 3:2 pulldown flags. If your software doesn't perform the pulldown to 29.97 fps you will get 23.976 fps progressive frames. Anime and some television shows are the exceptions -- they are often encoded 29.97 fps interlaced.
  6. Banned
    Again: what video's resolution has to do with (whatever better or worse) deinterlacing job?
  7. Originally Posted by seekt
    Yeah, I think seekt needs to do some serious reading. A height of 272 is often a 640x272 2.35:1 AVI and has nothing by itself to do with PAL/NTSC or with deinterlacing. If the framerate is 25fps, the source was likely a PAL DVD and if 23.976fps, probably from an NTSC DVD.
    As for a height of 384 pixels, those are often 1.33:1 512x384 AVIs as DereX888 also speculated and, again, nothing to do with deinterlacing.
    It's not only possible to achieve the quality you've seen, but sometimes (often?) possible to achieve better quality, if you know what you're doing.
    If you want to get started on converting DVD to AVI, I might suggest taking a look at AutoGK.
    According to 100fps.com:
    "When you buy a DVD, some are encoded with interlaced frames and some are progressive. The output is always interlaced of course (except for some special DVD players) because TV Sets usually don't support progressive input."
    I really don't believe that a progressive encoded dvd would be the same picture quality as an interlaced one.
    The reason should be obvious.
    Think dudes, think.
    Why don't you spell it out for us?
    An even better quote from 100fps.com:
    "There are 2 kinds of DVDs: Some have an interlaced format (like the examples above) and some are transferred from film to DVD directly, thus have 25 progressive frames encoded. This is purely a decision of the DVD company."
    Why would the company choose progressive over interlaced?
    Scroll down 100fps a little and you'll find the answer.
    There is nothing there about why progressive encoding is better than interlaced encoding.
    And the author there has only a basic knowledge of interlaced video and how to handle it. Many of his samples show incorrect handling of the chroma channels and he doesn't even realize it. See the section where he says "some digital camcorders have something you could call "color interlacing." His interlaced sources could have been deinterlaced much better and without the chroma problems.
    Your understanding of interlaced video and how to handle it is even poorer. It has already been explained that most film sourced DVDs are not encoded interlaced. So there is no reason to perform a drop field deinterlace when converting to progressive AVI formats.
    According to 100fps.com: ... I really don't believe that a progressive encoded dvd would be the same picture quality as an interlaced one.
    Think dudes, think.
    I'm really happy that you're looking into things and doing some research. However, you're interpreting the info that you've seen so far incorrectly. As other have pointed out you need to understand some terminology first. The 'What Is' section would do you wonders. Listening to the likes of jagabo and manono.
    As far as your statement above: I don't see the same quality either when watching a DVD in interlaced 480i or its native 480p!
    The ingredients:
    - DVD
    - DVD Player
    - Display (TV/Monitor)
    In most cases, NTSC DVDs are 480p natively. However, a older non-progressive scan (ie. interlaced) player will output this in 480i so that it could match its display, usually a interlaced TV. Now fast forward to today, taking that same 480p but using a progressive scan DVD player and a progressive scan display and you have a MUCH cleaner picture. No conversions necessary.
    I guess you can say a non-progressive scan DVD player 'dumbed' down the picture for the sake of the display but future proofed for when progressive scan displays were more widely available. (Though there have been progressive scan TVs available but they were quite expensive. Same for progressive scan DVD players.)
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  13. I would like to reiterate that the 100fps site isn't the guidebook or manual or bible for anything. Much of the information found on that site is just plain wrong, some misleading.
    I also think you're confusing a progressive source with how it's been encoded. Most PAL movies on DVD use a progressive source, but those same PAL movies are encoded as interlaced. And they don't show any of the fine horizontal black lines often called 'combing'. As for NTSC DVDs, most are encoded as progressive with 3:2 pulldown applied so that they output interlaced 29.97fps. Some have in the past been, and some still are, encoded as interlaced 29.97fps, with the telecine encoded into the video. This kind is inferior to the progressively encoded ones.
    For NTSC you definitely want a progressively encoded DVD, for encoder efficiency if for no other reason. For PAL it doesn't seem to make a whole lot of difference, unless you have phase-shifted fields, funky NTSC2PAL conversions, or other foul-ups.
  14. Member edDV's Avatar
    This all assumes a progressive source and doesn't apply to consumer camcorders or "live" TV. This subject is more complicated than it first appears.
  15. Originally Posted by edDV
    This all assumes a progressive source...
    Yes it does, but as near as I can tell that's what seekt is discussing - movies on DVD:
    edDV,
    And since all NTSC DVDs output interlaced 29.97fps, many apps that might give information on the video will show even progressively encoded MPEG-2 video as interlaced 29.97fps. GSpot does this, for example, although a closer reading of the information given will tell you how it was really encoded.
    I was reading about this right now. It has been said that the best way to reconstruct the progressive frames would be through inverse telecine, but it is not a perfect process and leaves interlaced frames. I tried it myself and could see that indeed VirtualDub is not able to identify all telecine. The other way mentioned, deinterlacing, is what I tried earlier.
    The ingredients:
    - DVD
    - DVD Player
    I have never put my hands on a PAL DVD, but I'm suspicious of their quality being much better than NTSC. Mixing interlaced and progressive means degrading the project's final vertical resolution. In my opinion, NTSC's picture quality stays between 480 and 240 pixels. Even the progressive frames are not commited to full 480 pixels quality since the final motion picture is already compromised by those 2 telecine frames ahead.
    The great interrogation arised in my head after I downloaded a DVDRip that makes my NTSC DVD look like youtube video. And my DVD makes that DVDRip look like High Definition.
  17. Originally Posted by seekt
    You IVTC using an AviSynth script and one of its IVTC filters, and not the lousy IVTC in VDub. That's if it needs an IVTC. And if it does, then deinterlacing it is exactly the wrong thing to do. You might post a small 10 second sample of the video - a sample showing steady movement - so we can understand how best to treat it.
    Again, I suggest that if you're converting a DVD to AVI (XviD, DivX), that you try AutoGK. It can easily IVTC the video, if that's what's needed.
    Some of what you say is nonsensical; the rest is just plain wrong.
  18. Member
    I suspect you are dealing with animated material which often has a mix of 24 fps progressive, 30 fps progressive (30 different pictures per second), and 30 fps interlaced (60 different pictures per second). In addition to that some of the character animation is done around 12 or 15 fps with simple frame repeats to create 24 or 30 fps progressive frames. The only way to get the 24p, 30p, and 30i sections all to play smoothly is to (smart) bob to 60 fps.
    Of course is nonsensical and wrong, since you believe that you are right and everyone else wrong. The guy from 100fps is the fool and you the master. People that focus on finding fault on other's speech are never concerned in learning but bragging about their own knowledge. Neither 100fps is the guide, manual or bible for anything, nor you.
    Again, if you're so good, read 100fps and perceive the obvious that you still wasn't able to learn. Pay close attention to edDV's last reply. He's right, camcorders and live TV has everything to do with what I'm talking about.
    I guaranty you, manono knows far more about interlaced video than the author at 100fps.
    +1
  22. Member
    Uh, he knows far more about INTERLACED VIDEO. And according to his own words, 100fps isn't a guide for ANYTHING. Quite hard word to use, don't you think? Or do you think this is nonsense and plain wrong?
    Video Fundamentalism
  23. Member
    manono... according to his own words, 100fps isn't a guide for ANYTHING. Quite hard word to use, don't you think?
    Yes. I found the site useful when I was first learning about interlaced video and deinterlacing. But now that I know more I can see it has its shortcomings and errors. Tools have advanced quite a lot since it was written, many years ago.
    Quite hard on him, don't you think?
  24. Member
    You won't find a guy that knows more about DVD than manono.
    Post a sample from your original source
    If it's a "regular" hollywood movie it's likely just IVTCed using high quality avisynth methods (not vdub filters)
    If it's foreign anime, it might be hybrid, like jagabo mentioned. You could process it with avisynth methods like animeivtc
  25. Member
    Pride makes people quite hard on others... words denouncing that should be in fact quite hard on them.
  26. Member
    OK. You're a fucking idiot who's read a few web sites and now thinks he's an expert on deinterlacing. Happy?
  27. Member
    I think you know too much.
    poisondeathray said, "You won't find a guy that knows more about DVD than manono. ". So, is he the cult leader?
    Reputation doesn't make me take anyone seriously, character does.
  28. Member
    Nope. A "cult leader" is a figure that someone follows blindly.
    I respect manono because he knows his stuff and knowlegable guy - especially about DVD stuff. Dig up some of his old posts. You will be amazed. He doesn't get paid to help here. He is volunteering his time.
    Seriously, if you want help, at least try to entertain some of the suggestions. If you don't want help then keep on doing whatever it is you're doing (making crappy DVD rips)...
    And what does this thread say about your character ?
    Cheers
  29. Banned
    seekt
    Dude, WTF is wrong with you?
    You can deinterlace any interlaced video better or worse, it's up to your tools and skills.
    Yet it still has nothing to do with your final video's resolution, for which you may or may not use better or worse resizing.
    Deinterlacing and resizing are TWO DIFFERENT PROCESSES.
    How fucking hard is it to understand!
  30. Member
    My last word is:
    "I downloaded a DVDRip that makes my NTSC DVD look like youtube video. And my DVD makes that DVDRip look like High Definition."
    Since I don't have to prove anything to anyone understimating me, I won't upload anything.
    No, it's not possible to make one picture the same quality as the other. All the knowledge and all the tools in the world won't help you.
    Believe it,
    or not.
    Topic closed.
  1. Replies: 29
    Last Post: 30th Oct 2011, 16:22
  2. BD/DVD Interlace vs Progressive Scan: Which is better?
    By Bonie81 in forum Newbie / General discussions
    Last Post: 2nd Dec 2010, 06:01
  3. Do laptop dvd drives play in progressive scan?
    By ieh4f in forum Newbie / General discussions
    Last Post: 29th May 2008, 19:36
  4. Replies: 7
    Last Post: 27th May 2007, 00:39
  5. Creating DVD for progressive scan DVDplayer/TV
    By halsboss in forum Authoring (DVD)
    Last Post: 18th May 2007, 19:58
