    I just got a new Acer PC Triple core, 4GB ram, Vista home Premium 64bit. Full HD support.
    So I plug in my A1U and my new PC only recognizes(under device manager) my camera being plugged in when it's set to VCR/DV and I can import all the standard def footage I want. But when I set it to VCR/HDV, Vista says my camera is not even plugged in. After searching around I think it might be a Driver issue because with my XP it's the same problem.
    Also I can import and the HDV footage into my Macbook pro so I think it's definitely a driver issue.
    Any suggestions would be greatly appreciated!
    This may be some help to: http://www.sonyhdvinfo.com/archive/index.php/t-620.html
  2. try hdvsplit. see if it can find the cam.
    It's allright guys I figured it out.
  1. Sony HDV HC5 Camcorder and Firewire Cable
    By fjmr in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 7th Jul 2008, 06:38
  2. Re:Importing from camcorder
    By gepuk2001 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 17th Nov 2007, 19:15
  3. Oppinion on Sony HDR-HC3 HDV 1080I CAMCORDER
    By jtoolman2000 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 19th Oct 2006, 11:15
  4. ADOBE PREMIER PRO 2 with Sony HVR-A1U HDV Camera
    By SuperCharger in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 21st Jul 2006, 02:23
  5. sony HDV driver issue.. urgent :|
    By [.Q.] in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 16th Jul 2006, 11:43
About   Advertise   Forum   RSS Feeds   Statistics   Tools
