Hey all,
I am new to these forums and have not yet lurked around so please pardon me if this has already been discussed...
I am editing with Final Cut Pro 6 on a relatively new MacBook Pro (2.8 GHz and 4 GB Memory). I run my project files off of one external hard drive and save all my rough cuts, finals, capture scratch, etc. on another. I mainly edit in HD video now...mostly 1080 24p at top quality resolution (I shoot on a JVC HM100U ProCamcorder).
The long and short of it is...that I am currently working on a project and I am doing extremely beginners animation for the opening title sequence...so I have an image underneath text that moves...My question is: Why does it take SO LONG to render??? I am aware that Final Cut Pro inherently takes a while to render text simply because it has to create each frame, but we're talking a minimum of a half hour for maybe 10-20 seconds worth of an animation.
Can anyone shed some light on this situation?
Jared
jared@wheelandtorque.com
Probably best asked and answered in our Mac Forum. Moving you.
And welcome to our forums.
SORRY! as I said I'm newOriginally Posted by redwudz
What is the exact format of the underlying video? If you leave off the title but make some sort of alteration to the video, how long does it take to render the alteration?
I am shooting in 1080 at 24 frames with a 1920 X not sure resolution. Again, it all depends on what I am doing...When it comes to footage rendering time is decently quick, but when I do graphics, animation, or text, it DRAMATICALLY slows down.Originally Posted by rumplestiltskin
Some key points to consider:
* Fonts should not be font info, but should be flattened as a bitmap.
* All Graphics should not be bigger than ACTUAL SIZE, 72dpi.
Anything bigger than that and FCP will throw out those extra pixels.
*Animations are best imported in as Quicktime .mov files,
with all layers flattened, (text especially), sized to actual size
of your timeline, to avoid long render times in FCP.
Now look at the above, and compare to what you are having problems
with and see how you can fix yours."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Ways to speed up rendering with VirtualDub + Avisynth?
By Asterra in forum Newbie / General discussionsReplies: 6Last Post: 18th Apr 2011, 10:20 -
Rendering time changed
By liqt in forum EditingReplies: 1Last Post: 8th Jan 2011, 13:50 -
how to speed up rendering time with HD video
By The Linguist in forum Newbie / General discussionsReplies: 1Last Post: 17th Dec 2009, 05:31 -
How to speed up rendering time in Vegas? PS3
By Abiyad in forum EditingReplies: 4Last Post: 25th Jan 2008, 17:45 -
FCP Loading Time
By James in HD in forum MacReplies: 8Last Post: 25th Nov 2007, 10:12
