VideoHelp.com Forum
Results 1 to 10 of 10
    Hi hope some one can help see below for details, I have been using this set up for a while to capture various inputs vhs or digital recordings from the TV when the capturing had finished l then edit files with nero vision 3 which l find really easy to use however recently l have had a problem with the audio stream as in when l drag it into NV to edit/trim l get a high pitched squealing sound or rather a pixelated audio sound, a bit like a satellite transmission when the signal breaks up, in every file. I can ignore it and proceed with the edit which l have done but when l burn to disc the sound issue remains on the final product the picture quality is perfect and this has been working fine up to now, any ideas anyone is there a codec missing l have virtual dub but have not experimented with that yet.
    here is a recent capture I burnt
    How Not to Live You Life (Video Title, 0h 28m 13s)
    Video mode: PAL
    Aspect ratio: 4:3
    Quality: Long play (3382 kbps)
    Resolution: 720 x 576 (CCIR-601 D1)
    Audio SmartEncoding ratio: 0.0 %
    Video SmartEncoding ratio: 99.2 %
    HERE ARE THE CAPTURE SETTINGS
    Honest tech tvr 2.5
    device CX2388x video capture
    settings
    dvd-pal
    size (720x576)
    Frame Rate 25.00FPS
    CBR 60000bps
    quality normal
    enc speed normal
    minimun cpu intel P4 1.7ghz
    bit rate 6000 2801 mb/h
    Sample format: Automatic
    Audio format: Dolby Digital (AC-3) 2.0
    Encoding mode: Fast Encoding (1-Pass)
  2. Member hech54's Avatar
    What do your captures sound like in a player?
    "but when l burn to disc the sound issue remains"
    in the player it's the same stand alone or pc
    l should also mention that l can capture to alternative settings ie avi
    but the quality isn't as good but the audio is ok
  4. Member hech54's Avatar
    Run your captured file through GSpot and post the findings. Your end result on the DVD is AC3 audio but so far you have not said what your capture audio is.
    I also meant a "player". What does the audio sound like in a player like Windows Mediaplayer or VLC Player.
    ok l will do that and l will check WMP but l feel sure that it's the same and the audio is through the sound card FM801 (forte media) as it always was
    checked the wmp and it's the same, also l checked the audio and it's not through the sound card. The capture card handles the audio and the video
  7. Member hech54's Avatar
    Without a GSpot screenshot or description of the video and audio of your original capture file nobody will know how to help you.
    i shall do it tomorrow and upload it
    ok here is gspot file. Interestingly l recorded this in the format that is causing problems it's a stored recording on my sky (uk) digibox hard drive, again same audio problem, I also, while i was at it, recorded a live feed via the same digibox with the same capture card setup and when l imported it into NV the sound was fine!
  10. Member hech54's Avatar
    Edit your very first post in this thread and change it to mention a problem "capturing SKY broadcast". We have SKY here where I live but I don't have it and don't want it. I've read too many horror stories here on VideoHelp over the years.
  1. capturing from sky+ box to pc
    By supercoop in forum Capturing
    Last Post: 7th Jan 2012, 20:11
  2. Transferring Sky+ recordings to PC
    By grandsire02 in forum Newbie / General discussions
    Last Post: 21st Nov 2010, 15:37
  3. Problem with HD recordings from Myth HVR2250
    By dallasmn in forum SVCD2DVD & VOB2MPG
    Last Post: 15th Apr 2010, 21:59
  4. Sky + And/Or Sky HD Recording To Pc With DAZZLE
    By akenny01 in forum Capturing
    Last Post: 7th Mar 2008, 18:02
  5. TS Sky HD convertion problem
    By pablo_picasso in forum DVB / HDTV
    Last Post: 26th Aug 2007, 10:24
