System: Windows Vista 64-bit Service Pack 2
Software: VirtualDub 1.8.8 AMD64, ffdshow tryouts revision 3028 (64-bit, the version bundled with K-Lite Codec Pack x64), Avisynth 2.5 64-bit (the one last built by squid_80 from Doom9)
Whenever I open an AVI file that contains H.264-lossless video (encoded with x264 using "Single pass - lossless" option) directly with VirtualDub AMD64, I only get a solid black screen. If, instead of directly opening the AVI, I write an Avisynth script using AVISource() and open the AVS with VirtualDub AMD64, I get a solid green screen. If I manually specify the colorspace (RGB24 or YV12) either thru VirtualDub's Video\Color Depth menu or via the AVS, I get either solid black (RGB24) or solid green (YV12). However, when I open the same AVI or AVS with 32-bit VirtualDub, the video loads properly.
If, instead I use DirectShowSource() on my AVS and add Veedub64.exe to ffdshow's allowed application list, then VirtualDub AMD64 crashes when trying to open the AVS. However, the AVI itself plays properly on 64-bit Windows Media Player, given 64-bit ffdshow is installed.
What is wrong with what? VirtualDub AMD64? 64-bit ffdshow? 64-bit Avisynth? Or something else on Windows Vista 64-bit?
Well, I think I solved myself the problem. I just spotted a new version of VirtualDub AMD64 (1.9.6) AND a new revision of 64-bit ffdshow (3096). I can now directly open the lossless-H.264 AVI with VDub or open it via Avisynth 64-bit using AVISource() (DirectShowSource() will still crash VDub, however).
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 14:04 -
Which container for H.264 video and LPCM (or lossless) audio?
By fellowweb in forum Video ConversionReplies: 17Last Post: 3rd Sep 2009, 04:58 -
Lossless h.264 or avchd cutter
By yardline in forum Video ConversionReplies: 2Last Post: 4th Oct 2008, 10:21 -
Cannot split H.264 720P AVI using virtualdub
By frankyloves2sing in forum EditingReplies: 7Last Post: 24th Jun 2008, 19:55
Statistics
Newest guides
Latest tool updates
New media comments
