    Hello
    I have plugged in an external mic on my HV30 but I still get the sound from the internal cameramic. Im using a preamp in between, the juicedlinkas an external preamp.
    how do I disconnect the internal cameramic and just get the sound from the external?
    thanks for the quick reply. Im going to get up early tomorrow and shoot and start to feel a little panic
    thanks
    Per
  2. something wrong with your mic/amp. all that you need to do to use it is plug it in to the hv30. no power? bad pre-amp?
    works now. cause the internal mic shall be turned off automatically when I stick something into the external mic jack right?.
    seems to work now though. phuu
    any recommended volumesettings on the hv30 for use with external mic?
  1. Cannot capture with hv30
    By priceman1975 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Dec 2009, 22:24
  2. Such a deal...HV30
    By zoobie in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 20th Jun 2009, 14:45
  3. hv30 30p question
    By minidv2dvd in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 22nd Mar 2009, 23:49
  4. HV30 at 30p
    By Soopafresh in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 22nd May 2008, 06:25
  5. Replies: 7
    Last Post: 30th May 2006, 08:07
About   Advertise   Forum   RSS Feeds   Statistics   Tools
