VideoHelp.com Forum
    that is capable of adding subtitles, encoding, and burning a video all at once. Or is it not possible, I have to re-encode it first and then burn it once the subs are already hard modded. I want to get the best picture quality so I'd rather have the lossless video file burn it to dvd and only have to encode it once while still adding subtitles. thanks.
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Baldrick
    Please stop make new similar topics. Just ask all your questions in ONE topic.
    Use ConvertXtoDVD or DVD FLick(Free).
    thanks
    then from my other post i was really just wondering technically why Nero Vision could not burn with subtitles. is it a compatibility issue?
    And so basically converting it to video ts and audio ts is not encoding and does not alter quality in any way. so that way i can burn it str8 forward. thats the main thing i want to make sure of thanks.
  6. Always Watching guns1inger's Avatar
    If your source is DVD compliant mpeg-2 then it will not be re-encoded (if you are using DVD Flick you will have to tell it not to re-encode compliant material). If your material is not DVD compliant mpeg-2 then it will be re-encoded (it has to be to create a DVD). I can't say if it will affect the quality without knowing what the source material is.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  1. Simplest DVD authoring program?
    By paristideu in forum Authoring (DVD)
    Last Post: 28th Dec 2011, 11:08
  2. A good dvd authoring program?
    By t_jay17 in forum Authoring (DVD)
    Last Post: 31st Mar 2010, 21:50
  3. which dvd-authoring program is better?
    By siluet in forum Authoring (DVD)
    Last Post: 8th Oct 2008, 14:25
  4. What's a good dvd authoring program to use?
    By zanos in forum Authoring (DVD)
    Last Post: 3rd Mar 2008, 11:11
  5. The Best DVD Authoring program
    By Random490 in forum Authoring (DVD)
    Last Post: 12th Dec 2007, 04:10
