VideoHelp.com Forum
    Hey, so i'm trying to convert a DVD to an MKV file, I want to use AAC audio, and the x264 codec for the video in an MKV container - thing is, i'm trying to use AutoMKV, and each time I try and set up a file to be processed and start it, it stops when it gets to the audio converting stage:
    * NOTE! enc_aacplus.dll must be into executable directory
    * get it from Winamp 5.2 plugins directory
    * tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version)
    I'm using the standard build/release of AutoMKV (0.98.4), and it gives me this error. I also changed the enc_aacplus.dll file to a slightly different one which I found in winamp 5.2 (which it says to do above, in the error) - that didnt fix the error. Anyone know how to fix this annoying bug?
    Cheers
  2. Member Soopafresh's Avatar
    Use the AAC encoder from Nero. It's better quality and AutoMKV will use it.
    http://www.nero.com/eng/downloads-ne...aac-codec.php#
    "Quality is cool, but don't forget... Content is King!"
    OK cheers, i'll give it a shot.. But on the side, is there any way to get the normal one working? Just curious as to what the issue is here..
  4. automkv works with enc_aacplus bundled with automkv
    also, automkv is a ended project
    please use HDConverttoX
    thanks
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
  1. Automkv 0.98.4 error
    By mail2tom in forum Video Conversion
    Last Post: 22nd Aug 2009, 17:40
  2. AutoMKV audio error
    By Kalash109 in forum DVD Ripping
    Last Post: 4th May 2008, 11:57
  3. AutoMKV problem, warpsharp.dll failed to load
    By filanwizard in forum DVD Ripping
    Last Post: 21st Aug 2007, 08:32
  4. AutoMKV getting started error?
    By amdk62 in forum Video Conversion
    Last Post: 12th Jul 2007, 15:33
  5. AutoMKV Error
    By ^D3vIL^ in forum Newbie / General discussions
    Last Post: 8th May 2007, 05:01
