    Hello folks. I am a new user of SVCD2DVD, primarily using it to convert PAL to NTSC to send to a friend in North America.
    I have done a couple and been really pleased with the quality of the end result.
    I am using 1clickDVD to shrink the source DVD to the required size and then ripping the result files to my hard drive.
    I then use SVCD2DVD with the option QuickDVD (no menu or burn) and finally use 1click to burn the result to disc.
    I have an 'episode' type DVD which is causing my problem. I get the error (see below error followed by log file) right at the end when SVCD2DVD is authoring titleset #1 at 50%.
    I usually use 2 pass to get best quality but read a suggestion to try with just 1 pass - this produced the same error. SVCD2DVD is not installed in program files either.
    1clickDVD is usually good with episode files and the source disc plays fine on my DVD players.
    Any suggestions much appreciated. I am running Vista Basic SP1 on a 2GB intel. The log shows I was running low on disc space but I have run it earlier and got the same error when there was more disc space available. Having had a few crashes of this type I now need to clean up the crap as I had 27GB free when I started this morning!
    Error message:
    Version: SVCD2DVD 2.5
    Build: 2.5.5030.0
    Type: System.AccessViolationException
    Source: SVCD2DVD
    Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
    at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Threading.ThreadHelper.ThreadStart()
    Log:
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.5
    Version: 2.5.5030.0
    Executable: C:\svcdtodvd\SVCD2DVD.exe
    Executable size: 2.58 MB
    Executable size in bytes: 2711635
    Executable CreationTime: 28/01/2009 15:57:36
    Executable LastWriteTime: 08/10/2009 15:22:18
    Executable LastAccessTime: 08/10/2009 15:22:18
    ************************* Operating System *************************
    Operating System: Microsoft® Windows Vista™ Home Basic
    Service Pack: Service Pack 1
    Version : 6.0.6001
    Windows Directory : C:\Windows
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 44
    Local: 0809
    Total Physical Memory: 0.99 GB
    Free Physical Memory: 425 MB
    Total Virtual Memory: 2.24 GB
    Free Virtual Memory: 1.27 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: System manufacturer
    Computer Model: System Product Name
    System Type: X86-based PC
    Computer Name: TEMP-PC
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 1
    User Name: temp-PC\temp
    ***************************** Processor ****************************
    Manufacturer: GenuineIntel
    Processor: Intel(R) Celeron(R) CPU 440 @ 2.00GHz
    Description: x64 Family 6 Model 22 Stepping 1
    CPU Speed: 2GHz
    CPU FSB: 200MHz
    L2 Cache Size: 512 bytes
    ***************************** Time Zone ****************************
    Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
    ****************************** VIDEO *******************************
    Name: Intel(R) 82945G Express Chipset Family
    Processor: Intel(R) 82945G Express Chipset Family
    Mode: 1280 x 768 x 4294967296 colors
    Video Ram: 224 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 17.0 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <?xml version="1.0" encoding="utf-8"?>
    <SVCD2DVD DateTime="14/10/2009 08:41:25" Filename="C:\Users\temp\Documents\NTSC conversion files\if tomorrow comes disc 2 project.s2d">
    <AssetSet>
    <Asset ID="14ff2eca-bd24-4349-8e11-e352b4553a9c" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_01_0.VOB" />
    <Asset ID="4ddf9553-6307-4cba-b423-98d9f4fa1de9" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_01_1.VOB" />
    <Asset ID="d0b9b32a-478a-4332-8b1e-b23ad5597680" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_02_1.VOB" />
    <Asset ID="b00a63eb-1503-4cbe-9485-0ad58ea9ed83" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_03_1.VOB" />
    <Asset ID="c583dbe9-6ec8-4220-9fa4-75220ef4b75d" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_03_2.VOB" />
    <Asset ID="604cb759-5ae1-4ad8-96a3-4d0ee45b5936" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_1.VOB" />
    <Asset ID="3ae72a75-536d-4cb6-ae30-01d2f9965944" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_2.VOB" />
    <Asset ID="ea05380c-0429-4092-8eaf-62bdcfafac66" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_3.VOB" />
    </AssetSet>
    <DVDStructure>
    <TitleSet Name="VTS_01_0" PostCmd="" MenuButtonType="0">
    <MenuButton X1="0" Y1="0" X2="195" Y2="58" FontFamily="Arial Unicode MS" FontSize="27.75" FontStyle="3">VTS_01_0</MenuButton>
    <Title Name="VTS_01_0.VOB" AssetID="14ff2eca-bd24-4349-8e11-e352b4553a9c" MplexOffset="0" />
    <Title Name="VTS_01_1.VOB" AssetID="4ddf9553-6307-4cba-b423-98d9f4fa1de9" MplexOffset="0" />
    <Title Name="VTS_02_1.VOB" AssetID="d0b9b32a-478a-4332-8b1e-b23ad5597680" MplexOffset="0" />
    <Title Name="VTS_03_1.VOB" AssetID="b00a63eb-1503-4cbe-9485-0ad58ea9ed83" MplexOffset="0" />
    <Title Name="VTS_03_2.VOB" AssetID="c583dbe9-6ec8-4220-9fa4-75220ef4b75d" MplexOffset="0" />
    <Title Name="VTS_04_1.VOB" AssetID="604cb759-5ae1-4ad8-96a3-4d0ee45b5936" MplexOffset="0" />
    <Title Name="VTS_04_2.VOB" AssetID="3ae72a75-536d-4cb6-ae30-01d2f9965944" MplexOffset="0" />
    <Title Name="VTS_04_3.VOB" AssetID="ea05380c-0429-4092-8eaf-62bdcfafac66" MplexOffset="0" />
    </TitleSet>
    <DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\svcdtodvd\default.jpg" AudioPath="" />
    </DVDStructure>
    <Settings>
    <General InitialAssetFolder="C:\Users\temp\Documents\if tomorrow comes PAL" InitialDVDFolder="C:\Users\temp\Documents\NTSC conversion files" OutputFolderName="If Tomorrow Comes NTSC DVD" InitialProjectFolder="C:\Users\temp\Documents\NTSC conversion files" InitialMenuBackgroundFolder="C:\Users\temp\Documen ts\NTSC conversion files" DeleteS2DFiles="True" UseDVDShrink="False" />
    <Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="C:\Users\temp\Pictures\if tomorrow comes.jpg" TVStandard="NTSC" FontFamily="Arial Unicode MS" FontSize="27.75" FontStyle="3" PlayAllText="Play All episodes" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
    <Process AudioEncoding="ac3" Chapters="Every 30 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
    <Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
    <Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="True" DVDDDontBurn="False" />
    </Settings>
    </SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 2.56 MB
    file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_01_0.VOB
    FormatName=mpeg
    Num_Frames=1964
    DurationInSecs=79
    Duration=00:01:18.5
    VideoCodec=mpeg2video
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=274
    AudioStreamCount=1
    Audio1FFSTNum=2
    Audio1StreamID=[0x80]
    Audio1SampleRate=48000
    Audio1Codec=ac3
    Audio1BitRate=224
    Audio1Channels=2
    Processing VTS_01_0.VOB
    Leaving source audio alone.
    08:41:25: Converting PAL to NTSC (DVD Profile)
    File Size: 25.1 MB
    file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_01_1.VOB
    FormatName=mpeg
    Num_Frames=1084
    DurationInSecs=44
    Duration=00:00:43.3
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=4869
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    [VTS_01_0] 08:41:30: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_01_0] 08:41:30: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_01_0] 08:41:30: libavutil 49.12. 0 / 49.12. 0
    [VTS_01_0] 08:41:30: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_01_0] 08:41:30: libavformat 52.23. 1 / 52.23. 1
    [VTS_01_0] 08:41:30: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_01_0] 08:41:30: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_01_0] 08:41:30: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_01_0] 08:41:30: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_0.VOB':
    [VTS_01_0] 08:41:30: Duration: 00:01:18.56, start: 0.280000, bitrate: 274 kb/s
    [VTS_01_0] 08:41:30: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8000 kb/s, 25.00 tb(r)
    [VTS_01_0] 08:41:30: Stream #0.1[0x20]: Subtitle: dvdsub
    [VTS_01_0] 08:41:30: Stream #0.2[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_01_0] 08:41:30: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_0_S2D.mpg':
    [VTS_01_0] 08:41:30: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_01_0] 08:41:30: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_01_0] 08:41:30: Stream mapping:
    [VTS_01_0] 08:41:30: Stream #0.0 -> #0.0
    [VTS_01_0] 08:41:30: Stream #0.2 -> #0.1
    [VTS_01_0] 08:41:30: [mpeg2video @ 0x2a76b90]Using pulldown for PAL->NTSC.
    [VTS_01_0] 08:41:30: Press [q] to stop encoding
    [VTS_01_0] 08:41:30: video:0kB audio:2150kB global headers:0kB muxing overhead 1.773359%
    Processing VTS_01_1.VOB
    08:41:31: Converting PAL to NTSC (DVD Profile)
    File Size: 2.13 MB
    file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_02_1.VOB
    FormatName=mpeg
    Num_Frames=249
    DurationInSecs=10
    Duration=00:00:09.9
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=1799
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=224
    Audio1Channels=2
    [VTS_01_1] 08:41:31: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_01_1] 08:41:31: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_01_1] 08:41:31: libavutil 49.12. 0 / 49.12. 0
    [VTS_01_1] 08:41:31: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_01_1] 08:41:31: libavformat 52.23. 1 / 52.23. 1
    [VTS_01_1] 08:41:31: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_01_1] 08:41:31: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_01_1] 08:41:31: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_01_1] 08:41:31: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1.VOB':
    [VTS_01_1] 08:41:31: Duration: 00:00:43.39, start: 0.280000, bitrate: 4869 kb/s
    [VTS_01_1] 08:41:31: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8000 kb/s, 25.00 tb(r)
    [VTS_01_1] 08:41:31: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_01_1] 08:41:31: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1_S2D.mpg':
    [VTS_01_1] 08:41:31: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_01_1] 08:41:31: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_01_1] 08:41:31: Stream mapping:
    [VTS_01_1] 08:41:31: Stream #0.0 -> #0.0
    [VTS_01_1] 08:41:31: Stream #0.1 -> #0.1
    [VTS_01_1] 08:41:31: [mpeg2video @ 0x36ecc00]Using pulldown for PAL->NTSC.
    [VTS_01_1] 08:41:31: Press [q] to stop encoding
    [VTS_01_1] 08:41:51: video:31303kB audio:2375kB global headers:0kB muxing overhead 1.970993%
    Processing VTS_02_1.VOB
    08:41:53: Converting PAL to NTSC (DVD Profile)
    File Size: 0.99 GB
    file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_03_1.VOB
    FormatName=mpeg
    Num_Frames=69076
    DurationInSecs=2764
    Duration=00:46:03.0
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3108
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2StreamID=[0x81]
    Audio2SampleRate=48000
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    [VTS_02_1] 08:41:54: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_02_1] 08:41:54: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_02_1] 08:41:54: libavutil 49.12. 0 / 49.12. 0
    [VTS_02_1] 08:41:54: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_02_1] 08:41:54: libavformat 52.23. 1 / 52.23. 1
    [VTS_02_1] 08:41:54: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_02_1] 08:41:54: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_02_1] 08:41:54: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_02_1] 08:41:54: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1.VOB':
    [VTS_02_1] 08:41:54: Duration: 00:00:09.96, start: 0.280000, bitrate: 1799 kb/s
    [VTS_02_1] 08:41:54: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 9000 kb/s, 25.00 tb(r)
    [VTS_02_1] 08:41:54: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_02_1] 08:41:54: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1_S2D.mpg':
    [VTS_02_1] 08:41:54: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_02_1] 08:41:54: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_02_1] 08:41:54: Stream mapping:
    [VTS_02_1] 08:41:54: Stream #0.0 -> #0.0
    [VTS_02_1] 08:41:54: Stream #0.1 -> #0.1
    [VTS_02_1] 08:41:54: [mpeg2video @ 0x32ecfa0]Using pulldown for PAL->NTSC.
    [VTS_02_1] 08:41:54: Press [q] to stop encoding
    [VTS_02_1] 08:41:56: video:2158kB audio:244kB global headers:0kB muxing overhead 3.334255%
    Processing VTS_03_1.VOB
    08:41:58: Converting PAL to NTSC (DVD Profile)
    File Size: 966 MB
    file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_03_2.VOB
    FormatName=mpeg
    Num_Frames=64989
    DurationInSecs=2600
    Duration=00:43:19.5
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3120
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    [VTS_03_1] 08:41:59: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_03_1] 08:41:59: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_03_1] 08:41:59: libavutil 49.12. 0 / 49.12. 0
    [VTS_03_1] 08:41:59: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_03_1] 08:41:59: libavformat 52.23. 1 / 52.23. 1
    [VTS_03_1] 08:41:59: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_03_1] 08:41:59: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_03_1] 08:41:59: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_03_1] 08:41:59: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1.VOB':
    [VTS_03_1] 08:41:59: Duration: 00:46:03.07, start: 0.280000, bitrate: 3108 kb/s
    [VTS_03_1] 08:41:59: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_03_1] 08:41:59: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_03_1] 08:41:59: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_03_1] 08:41:59: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1_S2D.mpg':
    [VTS_03_1] 08:41:59: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_03_1] 08:41:59: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_03_1] 08:41:59: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_03_1] 08:41:59: Stream mapping:
    [VTS_03_1] 08:41:59: Stream #0.0 -> #0.0
    [VTS_03_1] 08:41:59: Stream #0.1 -> #0.1
    [VTS_03_1] 08:41:59: Stream #0.2 -> #0.2
    [VTS_03_1] 08:41:59: [mpeg2video @ 0x3ac0bb0]Using pulldown for PAL->NTSC.
    [VTS_03_1] 08:41:59: Press [q] to stop encoding
    [VTS_03_1] 08:42:07: [mpeg2video @ 0x2b2d4e0]mb incr damaged
    [VTS_03_1] 08:42:07: [mpeg2video @ 0x2b2d4e0]Warning MVs not available
    [VTS_03_1] 08:42:07: [mpeg2video @ 0x2b2d4e0]concealing 45 DC, 45 AC, 45 MV errors
    [VTS_03_1] 09:02:49: video:2023474kB audio:226660kB global headers:0kB muxing overhead 1.944771%
    Processing VTS_03_2.VOB
    09:02:51: Converting PAL to NTSC (DVD Profile)
    File Size: 0.99 GB
    file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_04_1.VOB
    FormatName=mpeg
    Num_Frames=57915
    DurationInSecs=2317
    Duration=00:38:36.6
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3707
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    [VTS_03_2] 09:02:52: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_03_2] 09:02:52: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_03_2] 09:02:52: libavutil 49.12. 0 / 49.12. 0
    [VTS_03_2] 09:02:52: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_03_2] 09:02:52: libavformat 52.23. 1 / 52.23. 1
    [VTS_03_2] 09:02:52: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_03_2] 09:02:52: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_03_2] 09:02:52: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_03_2] 09:02:52: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2.VOB':
    [VTS_03_2] 09:02:52: Duration: 00:43:19.58, start: 2763.352000, bitrate: 3120 kb/s
    [VTS_03_2] 09:02:52: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_03_2] 09:02:52: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_03_2] 09:02:52: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_03_2] 09:02:52: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2_S2D.mpg':
    [VTS_03_2] 09:02:52: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_03_2] 09:02:52: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_03_2] 09:02:52: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_03_2] 09:02:52: Stream mapping:
    [VTS_03_2] 09:02:52: Stream #0.0 -> #0.0
    [VTS_03_2] 09:02:52: Stream #0.1 -> #0.1
    [VTS_03_2] 09:02:52: Stream #0.2 -> #0.2
    [VTS_03_2] 09:02:52: [mpeg2video @ 0x18be570]Using pulldown for PAL->NTSC.
    [VTS_03_2] 09:02:52: Press [q] to stop encoding
    [VTS_03_2] 09:21:18: [dvd @ 0x18c2d40]buffer underflow i=1 bufi=1637 size=1792
    [VTS_03_2] 09:22:04: video:1902243kB audio:213248kB global headers:0kB muxing overhead 1.948279%
    Processing VTS_04_1.VOB
    09:22:05: Converting PAL to NTSC (DVD Profile)
    File Size: 0.99 GB
    file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_04_2.VOB
    FormatName=mpeg
    Num_Frames=57252
    DurationInSecs=2291
    Duration=00:38:10.1
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3750
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    [VTS_04_1] 09:22:07: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_04_1] 09:22:07: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_04_1] 09:22:07: libavutil 49.12. 0 / 49.12. 0
    [VTS_04_1] 09:22:07: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_04_1] 09:22:07: libavformat 52.23. 1 / 52.23. 1
    [VTS_04_1] 09:22:07: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_04_1] 09:22:07: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_04_1] 09:22:07: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_04_1] 09:22:07: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1.VOB':
    [VTS_04_1] 09:22:07: Duration: 00:38:36.60, start: 0.280000, bitrate: 3707 kb/s
    [VTS_04_1] 09:22:07: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_04_1] 09:22:07: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_1] 09:22:07: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_1] 09:22:07: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1_S2D.mpg':
    [VTS_04_1] 09:22:07: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_04_1] 09:22:07: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_1] 09:22:07: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_1] 09:22:07: Stream mapping:
    [VTS_04_1] 09:22:07: Stream #0.0 -> #0.0
    [VTS_04_1] 09:22:07: Stream #0.1 -> #0.1
    [VTS_04_1] 09:22:07: Stream #0.2 -> #0.2
    [VTS_04_1] 09:22:07: [mpeg2video @ 0x37b1ec0]Using pulldown for PAL->NTSC.
    [VTS_04_1] 09:22:07: Press [q] to stop encoding
    [VTS_04_1] 09:39:03: [mpeg2video @ 0x264d4e0]ac-tex damaged at 37 27
    [VTS_04_1] 09:39:03: [mpeg2video @ 0x264d4e0]Warning MVs not available
    [VTS_04_1] 09:39:03: [mpeg2video @ 0x264d4e0]concealing 405 DC, 405 AC, 405 MV errors
    [VTS_04_1] 09:39:03: video:1678856kB audio:190026kB global headers:0kB muxing overhead 1.948105%
    Processing VTS_04_2.VOB
    09:39:05: Converting PAL to NTSC (DVD Profile)
    File Size: 330 MB
    file=C:\\Users\\temp\\Documents\\if tomorrow comes PAL\\VTS_04_3.VOB
    FormatName=mpeg
    Num_Frames=19970
    DurationInSecs=799
    Duration=00:13:18.8
    VideoFFSTNum=2
    Width=720
    Height=576
    Standard=PAL
    BitRate=3468
    AudioStreamCount=2
    Audio1FFSTNum=0
    Audio1StreamID=[0x81]
    Audio1Codec=ac3
    Audio1BitRate=224
    Audio1Channels=2
    Audio2FFSTNum=1
    Audio2StreamID=[0x80]
    Audio2Codec=ac3
    Audio2BitRate=448
    Audio2Channels=6
    [VTS_04_2] 09:39:06: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_04_2] 09:39:06: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_04_2] 09:39:06: libavutil 49.12. 0 / 49.12. 0
    [VTS_04_2] 09:39:06: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_04_2] 09:39:06: libavformat 52.23. 1 / 52.23. 1
    [VTS_04_2] 09:39:06: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_04_2] 09:39:06: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_04_2] 09:39:06: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_04_2] 09:39:06: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2.VOB':
    [VTS_04_2] 09:39:06: Duration: 00:38:10.11, start: 2316.792000, bitrate: 3750 kb/s
    [VTS_04_2] 09:39:06: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_04_2] 09:39:06: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_2] 09:39:06: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_2] 09:39:06: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2_S2D.mpg':
    [VTS_04_2] 09:39:06: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_04_2] 09:39:06: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_2] 09:39:06: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_2] 09:39:06: Stream mapping:
    [VTS_04_2] 09:39:06: Stream #0.0 -> #0.0
    [VTS_04_2] 09:39:06: Stream #0.1 -> #0.1
    [VTS_04_2] 09:39:06: Stream #0.2 -> #0.2
    [VTS_04_2] 09:39:06: [mpeg2video @ 0x30fec10]Using pulldown for PAL->NTSC.
    [VTS_04_2] 09:39:06: Press [q] to stop encoding
    [VTS_04_2] 09:56:22: video:1677648kB audio:187862kB global headers:0kB muxing overhead 1.942952%
    Processing VTS_04_3.VOB
    09:56:25: Converting PAL to NTSC (DVD Profile)
    [VTS_04_3] 09:56:26: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_04_3] 09:56:26: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_04_3] 09:56:26: libavutil 49.12. 0 / 49.12. 0
    [VTS_04_3] 09:56:26: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_04_3] 09:56:26: libavformat 52.23. 1 / 52.23. 1
    [VTS_04_3] 09:56:26: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_04_3] 09:56:26: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_04_3] 09:56:26: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_04_3] 09:56:26: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3.VOB':
    [VTS_04_3] 09:56:26: Duration: 00:13:18.81, start: 4606.936000, bitrate: 3468 kb/s
    [VTS_04_3] 09:56:26: Stream #0.0[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_3] 09:56:26: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_3] 09:56:26: Stream #0.2[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_04_3] 09:56:26: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3_S2D.mpg':
    [VTS_04_3] 09:56:26: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_04_3] 09:56:26: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_3] 09:56:26: Stream #0.2: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_3] 09:56:26: Stream mapping:
    [VTS_04_3] 09:56:26: Stream #0.2 -> #0.0
    [VTS_04_3] 09:56:26: Stream #0.0 -> #0.1
    [VTS_04_3] 09:56:26: Stream #0.1 -> #0.2
    [VTS_04_3] 09:56:26: [mpeg2video @ 0x37f3fe0]Using pulldown for PAL->NTSC.
    [VTS_04_3] 09:56:26: Press [q] to stop encoding
    [VTS_04_3] 10:02:18: video:583352kB audio:65532kB global headers:0kB muxing overhead 1.933720%
    10:02:19: Done: Processing assets for DVD creation
    Authoring DVD Folders
    10:02:19: Creating TitleSet # 1
    10:02:19: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    10:02:19: -->: DVDFolders creating VTS
    10:02:19: -->: VTS 01
    10:02:19:
    DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_0_S2D.mpg...
    10:02:20:
    DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1_S2D.mpg...
    10:02:23:
    DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1_S2D.mpg...
    10:02:23:
    DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1_S2D.mpg...
    10:04:32:
    DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2_S2D.mpg...
    10:06:14:
    DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1_S2D.mpg...
    10:07:36:
    DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2_S2D.mpg...
    10:09:19:
    DVD Folders: Processing C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3_S2D.mpg...
    Drive C: has only 865 MB free.
    10:09:54:
  2. Member ChrissyBoy's Avatar
    Can you try omitting VTS_01_0.VOB as i think this a menu and could well be causing the problem?
    OK will do - I think you could be right. Thanks for fast response Chrissyboy.
    "Can you try omitting VTS_01_0.VOB as i think this a menu and could well be causing the problem? "
    I did that and it crashed in exactly the same place 50% of the way through Titleset #1.
    I just did another quick test using just one file of the set: VTS_01_1.VOB. This worked fine and the resultant DVD is another pre-movie intro video sequence so I know I can exclude that too if I can get the whole thing to convert.
    By the way when I add the assets in to SVCD2DVD some are not imported (i.e. rejected by your program) e.g. VTS_TS.VOB and VTS_02_0.VOB. 4 files in total each the same size - 154Kb.
    Here are the error message and associoated log file below again.
    Build: 2.5.5030.0
    Source: SVCD2DVD
    InnerException:
    Title: 2.5
    Version: 2.5.5030.0
    Version : 6.0.6001
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 44
    Local: 0809
    Free Physical Memory: 350 MB
    Total Virtual Memory: 2.23 GB
    Free Virtual Memory: 1.39 GB
    CPU Speed: 2GHz
    CPU FSB: 200MHz
    Video Ram: 224 MB
    Status: OK
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 25.0 GB
    <SVCD2DVD DateTime="14/10/2009 13:51:09" Filename="C:\Users\temp\Documents\NTSC conversion files\if tomorrow comes part 2.s2d">
    <AssetSet>
    <Asset ID="ac1b461f-f9d8-40fb-9a83-e11b42500857" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_01_1.VOB" />
    <Asset ID="cae91ff4-dae9-48f1-82fa-c311e10cf638" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_02_1.VOB" />
    <Asset ID="5646749f-d996-4a9d-b909-7e5181280de2" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_03_1.VOB" />
    <Asset ID="76f5eccf-a2c9-4bc8-b687-97fbcf38eae0" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_03_2.VOB" />
    <Asset ID="aee66c4e-7a36-40ac-87af-b0345157be27" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_1.VOB" />
    <Asset ID="1802acdc-113f-4e07-9827-18f8c991c4f7" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_2.VOB" />
    <Asset ID="f6ac670c-9eb3-41b4-aca8-fb0a369b23b8" Path="C:\Users\temp\Documents\if tomorrow comes PAL" Filename="VTS_04_3.VOB" />
    </AssetSet>
    <DVDStructure>
    <TitleSet Name="VTS_01_1" PostCmd="" MenuButtonType="0">
    <MenuButton X1="0" Y1="0" X2="195" Y2="58" FontFamily="Arial Unicode MS" FontSize="27.75" FontStyle="3">VTS_01_1</MenuButton>
    <Title Name="VTS_01_1.VOB" AssetID="ac1b461f-f9d8-40fb-9a83-e11b42500857" MplexOffset="0" />
    <Title Name="VTS_02_1.VOB" AssetID="cae91ff4-dae9-48f1-82fa-c311e10cf638" MplexOffset="0" />
    <Title Name="VTS_03_1.VOB" AssetID="5646749f-d996-4a9d-b909-7e5181280de2" MplexOffset="0" />
    <Title Name="VTS_03_2.VOB" AssetID="76f5eccf-a2c9-4bc8-b687-97fbcf38eae0" MplexOffset="0" />
    <Title Name="VTS_04_1.VOB" AssetID="aee66c4e-7a36-40ac-87af-b0345157be27" MplexOffset="0" />
    <Title Name="VTS_04_2.VOB" AssetID="1802acdc-113f-4e07-9827-18f8c991c4f7" MplexOffset="0" />
    <Title Name="VTS_04_3.VOB" AssetID="f6ac670c-9eb3-41b4-aca8-fb0a369b23b8" MplexOffset="0" />
    </TitleSet>
    <DVDMenu Normal="-1" Highlight="-32640" Active="-65536" ShowPlayAllButton="True" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Users\temp\Pictures\if tomorrow comes.jpg" AudioPath="">
    <PlayAllButton X1="202" Y1="482" X2="518" Y2="540" FontFamily="Arial Unicode MS" FontSize="27.75" FontStyle="3">Play All episodes</PlayAllButton>
    </DVDMenu>
    </DVDStructure>
    <Settings>
    <General InitialAssetFolder="C:\Users\temp\Documents\NTSC master" InitialDVDFolder="C:\Users\temp\Documents\NTSC conversion files" OutputFolderName="If Tomorrow Comes NTSC Master DVD" InitialProjectFolder="C:\Users\temp\Documents\NTSC conversion files" InitialMenuBackgroundFolder="C:\Users\temp\Documen ts\NTSC conversion files" DeleteS2DFiles="True" UseDVDShrink="False" />
    </Settings>
    </SVCD2DVD>
    File Size: 25.1 MB
    FormatName=mpeg
    Num_Frames=1084
    DurationInSecs=44
    Duration=00:00:43.3
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=4869
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    13:51:09: Converting PAL to NTSC (DVD Profile)
    File Size: 2.13 MB
    FormatName=mpeg
    Num_Frames=249
    DurationInSecs=10
    Duration=00:00:09.9
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=1799
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=224
    Audio1Channels=2
    [VTS_01_1] 13:51:09: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_01_1] 13:51:09: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_01_1] 13:51:09: libavutil 49.12. 0 / 49.12. 0
    [VTS_01_1] 13:51:09: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_01_1] 13:51:09: libavformat 52.23. 1 / 52.23. 1
    [VTS_01_1] 13:51:09: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_01_1] 13:51:09: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_01_1] 13:51:09: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_01_1] 13:51:09: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1.VOB':
    [VTS_01_1] 13:51:09: Duration: 00:00:43.39, start: 0.280000, bitrate: 4869 kb/s
    [VTS_01_1] 13:51:09: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8000 kb/s, 25.00 tb(r)
    [VTS_01_1] 13:51:09: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_01_1] 13:51:09: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_01_1_S2D.mpg':
    [VTS_01_1] 13:51:09: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_01_1] 13:51:09: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_01_1] 13:51:09: Stream mapping:
    [VTS_01_1] 13:51:09: Stream #0.0 -> #0.0
    [VTS_01_1] 13:51:09: Stream #0.1 -> #0.1
    [VTS_01_1] 13:51:09: [mpeg2video @ 0x360cc00]Using pulldown for PAL->NTSC.
    [VTS_01_1] 13:51:09: Press [q] to stop encoding
    [VTS_01_1] 13:51:30: video:31303kB audio:2375kB global headers:0kB muxing overhead 1.970993%
    13:51:31: Converting PAL to NTSC (DVD Profile)
    File Size: 0.99 GB
    FormatName=mpeg
    Num_Frames=69076
    DurationInSecs=2764
    Duration=00:46:03.0
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3108
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    [VTS_02_1] 13:51:32: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_02_1] 13:51:32: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_02_1] 13:51:32: libavutil 49.12. 0 / 49.12. 0
    [VTS_02_1] 13:51:32: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_02_1] 13:51:32: libavformat 52.23. 1 / 52.23. 1
    [VTS_02_1] 13:51:32: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_02_1] 13:51:32: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_02_1] 13:51:32: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_02_1] 13:51:32: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1.VOB':
    [VTS_02_1] 13:51:32: Duration: 00:00:09.96, start: 0.280000, bitrate: 1799 kb/s
    [VTS_02_1] 13:51:32: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 9000 kb/s, 25.00 tb(r)
    [VTS_02_1] 13:51:32: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_02_1] 13:51:32: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_02_1_S2D.mpg':
    [VTS_02_1] 13:51:32: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_02_1] 13:51:32: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_02_1] 13:51:32: Stream mapping:
    [VTS_02_1] 13:51:32: Stream #0.0 -> #0.0
    [VTS_02_1] 13:51:32: Stream #0.1 -> #0.1
    [VTS_02_1] 13:51:32: [mpeg2video @ 0x30ecfa0]Using pulldown for PAL->NTSC.
    [VTS_02_1] 13:51:32: Press [q] to stop encoding
    [VTS_02_1] 13:51:34: video:2158kB audio:244kB global headers:0kB muxing overhead 3.334255%
    13:51:36: Converting PAL to NTSC (DVD Profile)
    File Size: 966 MB
    FormatName=mpeg
    Num_Frames=64989
    DurationInSecs=2600
    Duration=00:43:19.5
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3120
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    [VTS_03_1] 13:51:37: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_03_1] 13:51:37: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_03_1] 13:51:37: libavutil 49.12. 0 / 49.12. 0
    [VTS_03_1] 13:51:37: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_03_1] 13:51:37: libavformat 52.23. 1 / 52.23. 1
    [VTS_03_1] 13:51:37: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_03_1] 13:51:37: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_03_1] 13:51:37: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_03_1] 13:51:37: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1.VOB':
    [VTS_03_1] 13:51:37: Duration: 00:46:03.07, start: 0.280000, bitrate: 3108 kb/s
    [VTS_03_1] 13:51:37: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_03_1] 13:51:37: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_03_1] 13:51:37: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_03_1] 13:51:37: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_1_S2D.mpg':
    [VTS_03_1] 13:51:37: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_03_1] 13:51:37: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_03_1] 13:51:37: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_03_1] 13:51:37: Stream mapping:
    [VTS_03_1] 13:51:37: Stream #0.0 -> #0.0
    [VTS_03_1] 13:51:37: Stream #0.1 -> #0.1
    [VTS_03_1] 13:51:37: Stream #0.2 -> #0.2
    [VTS_03_1] 13:51:37: [mpeg2video @ 0x36e0bb0]Using pulldown for PAL->NTSC.
    [VTS_03_1] 13:51:37: Press [q] to stop encoding
    [VTS_03_1] 13:51:45: [mpeg2video @ 0x2a1d4e0]mb incr damaged
    [VTS_03_1] 13:51:45: [mpeg2video @ 0x2a1d4e0]Warning MVs not available
    [VTS_03_1] 13:51:45: [mpeg2video @ 0x2a1d4e0]concealing 45 DC, 45 AC, 45 MV errors
    [VTS_03_1] 14:12:01: video:2023474kB audio:226660kB global headers:0kB muxing overhead 1.944771%
    14:12:02: Converting PAL to NTSC (DVD Profile)
    File Size: 0.99 GB
    FormatName=mpeg
    Num_Frames=57915
    DurationInSecs=2317
    Duration=00:38:36.6
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3707
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    [VTS_03_2] 14:12:04: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_03_2] 14:12:04: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_03_2] 14:12:04: libavutil 49.12. 0 / 49.12. 0
    [VTS_03_2] 14:12:04: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_03_2] 14:12:04: libavformat 52.23. 1 / 52.23. 1
    [VTS_03_2] 14:12:04: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_03_2] 14:12:04: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_03_2] 14:12:04: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_03_2] 14:12:04: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2.VOB':
    [VTS_03_2] 14:12:04: Duration: 00:43:19.58, start: 2763.352000, bitrate: 3120 kb/s
    [VTS_03_2] 14:12:04: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_03_2] 14:12:04: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_03_2] 14:12:04: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_03_2] 14:12:04: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_03_2_S2D.mpg':
    [VTS_03_2] 14:12:04: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_03_2] 14:12:04: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_03_2] 14:12:04: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_03_2] 14:12:04: Stream mapping:
    [VTS_03_2] 14:12:04: Stream #0.0 -> #0.0
    [VTS_03_2] 14:12:04: Stream #0.1 -> #0.1
    [VTS_03_2] 14:12:04: Stream #0.2 -> #0.2
    [VTS_03_2] 14:12:04: [mpeg2video @ 0x302e570]Using pulldown for PAL->NTSC.
    [VTS_03_2] 14:12:04: Press [q] to stop encoding
    [VTS_03_2] 14:30:09: [dvd @ 0x3032d40]buffer underflow i=1 bufi=1637 size=1792
    [VTS_03_2] 14:30:56: video:1902243kB audio:213248kB global headers:0kB muxing overhead 1.948279%
    14:30:58: Converting PAL to NTSC (DVD Profile)
    File Size: 0.99 GB
    FormatName=mpeg
    Num_Frames=57252
    DurationInSecs=2291
    Duration=00:38:10.1
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3750
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    [VTS_04_1] 14:30:59: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_04_1] 14:30:59: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_04_1] 14:30:59: libavutil 49.12. 0 / 49.12. 0
    [VTS_04_1] 14:30:59: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_04_1] 14:30:59: libavformat 52.23. 1 / 52.23. 1
    [VTS_04_1] 14:30:59: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_04_1] 14:30:59: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_04_1] 14:30:59: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_04_1] 14:30:59: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1.VOB':
    [VTS_04_1] 14:30:59: Duration: 00:38:36.60, start: 0.280000, bitrate: 3707 kb/s
    [VTS_04_1] 14:30:59: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_04_1] 14:30:59: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_1] 14:30:59: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_1] 14:30:59: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_1_S2D.mpg':
    [VTS_04_1] 14:30:59: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_04_1] 14:30:59: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_1] 14:30:59: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_1] 14:30:59: Stream mapping:
    [VTS_04_1] 14:30:59: Stream #0.0 -> #0.0
    [VTS_04_1] 14:30:59: Stream #0.1 -> #0.1
    [VTS_04_1] 14:30:59: Stream #0.2 -> #0.2
    [VTS_04_1] 14:30:59: [mpeg2video @ 0x3631ec0]Using pulldown for PAL->NTSC.
    [VTS_04_1] 14:30:59: Press [q] to stop encoding
    [VTS_04_1] 14:47:47: [mpeg2video @ 0x28bd4e0]ac-tex damaged at 37 27
    [VTS_04_1] 14:47:47: [mpeg2video @ 0x28bd4e0]Warning MVs not available
    [VTS_04_1] 14:47:47: [mpeg2video @ 0x28bd4e0]concealing 405 DC, 405 AC, 405 MV errors
    [VTS_04_1] 14:47:47: video:1678856kB audio:190026kB global headers:0kB muxing overhead 1.948105%
    14:47:47: Converting PAL to NTSC (DVD Profile)
    File Size: 330 MB
    FormatName=mpeg
    Num_Frames=19970
    DurationInSecs=799
    Duration=00:13:18.8
    VideoFFSTNum=2
    Width=720
    Height=576
    Standard=PAL
    BitRate=3468
    AudioStreamCount=2
    Audio1FFSTNum=0
    Audio1Codec=ac3
    Audio1BitRate=224
    Audio1Channels=2
    Audio2FFSTNum=1
    Audio2Codec=ac3
    Audio2BitRate=448
    Audio2Channels=6
    [VTS_04_2] 14:47:49: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_04_2] 14:47:49: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_04_2] 14:47:49: libavutil 49.12. 0 / 49.12. 0
    [VTS_04_2] 14:47:49: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_04_2] 14:47:49: libavformat 52.23. 1 / 52.23. 1
    [VTS_04_2] 14:47:49: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_04_2] 14:47:49: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_04_2] 14:47:49: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_04_2] 14:47:49: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2.VOB':
    [VTS_04_2] 14:47:49: Duration: 00:38:10.11, start: 2316.792000, bitrate: 3750 kb/s
    [VTS_04_2] 14:47:49: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_04_2] 14:47:49: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_2] 14:47:49: Stream #0.2[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_2] 14:47:49: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_2_S2D.mpg':
    [VTS_04_2] 14:47:49: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_04_2] 14:47:49: Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_2] 14:47:49: Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_2] 14:47:49: Stream mapping:
    [VTS_04_2] 14:47:49: Stream #0.0 -> #0.0
    [VTS_04_2] 14:47:49: Stream #0.1 -> #0.1
    [VTS_04_2] 14:47:49: Stream #0.2 -> #0.2
    [VTS_04_2] 14:47:49: [mpeg2video @ 0x2b9ec10]Using pulldown for PAL->NTSC.
    [VTS_04_2] 14:47:49: Press [q] to stop encoding
    [VTS_04_2] 15:05:04: video:1677648kB audio:187862kB global headers:0kB muxing overhead 1.942952%
    15:05:05: Converting PAL to NTSC (DVD Profile)
    [VTS_04_3] 15:05:06: FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
    [VTS_04_3] 15:05:06: configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl --enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --disable-devices
    [VTS_04_3] 15:05:06: libavutil 49.12. 0 / 49.12. 0
    [VTS_04_3] 15:05:06: libavcodec 52. 6. 0 / 52. 6. 0
    [VTS_04_3] 15:05:06: libavformat 52.23. 1 / 52.23. 1
    [VTS_04_3] 15:05:06: libavdevice 52. 1. 0 / 52. 1. 0
    [VTS_04_3] 15:05:06: libswscale 0. 6. 1 / 0. 6. 1
    [VTS_04_3] 15:05:06: built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080502
    [VTS_04_3] 15:05:06: Input #0, mpeg, from 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3.VOB':
    [VTS_04_3] 15:05:06: Duration: 00:13:18.81, start: 4606.936000, bitrate: 3468 kb/s
    [VTS_04_3] 15:05:06: Stream #0.0[0x81]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_3] 15:05:06: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_3] 15:05:06: Stream #0.2[0x1e0]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 8500 kb/s, 25.00 tb(r)
    [VTS_04_3] 15:05:06: Output #0, dvd, to 'C:\Users\temp\Documents\if tomorrow comes PAL\VTS_04_3_S2D.mpg':
    [VTS_04_3] 15:05:06: Stream #0.0: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], q=1-31, 6000 kb/s, 25.00 tb(c)
    [VTS_04_3] 15:05:06: Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
    [VTS_04_3] 15:05:06: Stream #0.2: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
    [VTS_04_3] 15:05:06: Stream mapping:
    [VTS_04_3] 15:05:06: Stream #0.2 -> #0.0
    [VTS_04_3] 15:05:06: Stream #0.0 -> #0.1
    [VTS_04_3] 15:05:06: Stream #0.1 -> #0.2
    [VTS_04_3] 15:05:06: [mpeg2video @ 0x37d3fe0]Using pulldown for PAL->NTSC.
    [VTS_04_3] 15:05:06: Press [q] to stop encoding
    [VTS_04_3] 15:10:58: video:583352kB audio:65532kB global headers:0kB muxing overhead 1.933720%
    15:10:59: Done: Processing assets for DVD creation
    15:10:59: Creating TitleSet # 1
    15:10:59: SVCD2DVD: DVDfolders
    15:10:59: -->: DVDFolders creating VTS
    15:10:59: -->: VTS 01
    15:10:59:
    15:11:07:
    15:11:07:
    15:13:07:
    15:14:44:
    15:16:10:
    15:17:39:
    15:18:12:
  5. Member ChrissyBoy's Avatar
    I think the issue is mixing of the old titlesets into a single titleset:
    File Size: 25.1 MB
    FormatName=mpeg
    Num_Frames=1084
    DurationInSecs=44
    Duration=00:00:43.3
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=4869
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    File Size: 2.13 MB
    FormatName=mpeg
    Num_Frames=249
    DurationInSecs=10
    Duration=00:00:09.9
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=1799
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=224
    Audio1Channels=2
    File Size: 0.99 GB
    FormatName=mpeg
    Num_Frames=69076
    DurationInSecs=2764
    Duration=00:46:03.0
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3108
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    File Size: 966 MB
    FormatName=mpeg
    Num_Frames=64989
    DurationInSecs=2600
    Duration=00:43:19.5
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3120
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    File Size: 0.99 GB
    FormatName=mpeg
    Num_Frames=57915
    DurationInSecs=2317
    Duration=00:38:36.6
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3707
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    File Size: 0.99 GB
    FormatName=mpeg
    Num_Frames=57252
    DurationInSecs=2291
    Duration=00:38:10.1
    VideoFFSTNum=0
    Width=720
    Height=576
    Standard=PAL
    BitRate=3750
    AudioStreamCount=2
    Audio1FFSTNum=1
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    Audio2FFSTNum=2
    Audio2Codec=ac3
    Audio2BitRate=224
    Audio2Channels=2
    File Size: 330 MB
    FormatName=mpeg
    Num_Frames=19970
    DurationInSecs=799
    Duration=00:13:18.8
    VideoFFSTNum=2
    Width=720
    Height=576
    Standard=PAL
    BitRate=3468
    AudioStreamCount=2
    Audio1FFSTNum=0
    Audio1Codec=ac3
    Audio1BitRate=224
    Audio1Channels=2
    Audio2FFSTNum=1
    Audio2Codec=ac3
    Audio2BitRate=448
    Audio2Channels=6
    The number of audio streams differ in the assets and that is not allowed in a single titleset.
    So basically you need to seperate out the titles based on audio/video attributes:
    Title: VTS_01_1.VOB (ac3 5.1)
    Title: VTS_02_1.VOB (ac3 2.0)
    Title: VTS_03_X.VOB (2 AC3 streams)
    Title: VTS_04_x.VOB (2 AC3 streams)
    This is probably why it was authored this way in the first instance.
    Anyway the Play All Menu button will "string them together".
    I got rid of the rogue different audio segments (which were all pre-movie crap anyway and the conversion worked perfectly.
    This has given a bit more confidence to get in to the nuts and bolts of how this all works so many thanks Chrissyboy for your patient and fast responses.
    You have authored a great product, the results from which will make folk all over the world very happy!
  7. Member ChrissyBoy's Avatar
    Nice one!
    Hi all
    I have this problem listed above and the solution looks a good one but...
    I am putting together a compilation of music video's taken from several different places. In ripping these video's I often had to select different audio streams as occasionally the commentary would come up over the music.
    I now have all the Mpg's with the audio's the way I want I want using Vob2mpg but I have different d audio streams mixed throughout the collection.
    Is their a way I can run a script across all the files to 'Line up' all the audio streams or will I have to go a re-rip all the video's…….. or is there a way I could find out which mpg's are causing the issue.
    I could use the 'play all' option but that would make the menu a lot longer than would really suit. Or is there a way I can create submenu's.
    Many thanks in advance
    dunncha
  1. Attempted to read or write protected memory.
    By big40dog in forum SVCD2DVD & VOB2MPG
    Last Post: 17th Jan 2009, 07:51
  2. Memory could not be read error
    By MTD in forum Newbie / General discussions
    Last Post: 29th Dec 2006, 15:30
  3. SVCD2DVD more VTS Error READ Memory
    By Onelucky2 in forum SVCD2DVD & VOB2MPG
    Last Post: 4th May 2004, 05:49
  4. memory can not be read error - Moviestar
    By brimeis in forum Capturing
    Last Post: 28th Aug 2002, 00:48
  5. TmpegEnc: Memory read error encoding SVCD?
    By daveross in forum DVD Ripping
    Last Post: 6th Sep 2001, 17:08
About   Advertise   Forum   RSS Feeds   Statistics   Tools
