VideoHelp.com Forum
Page 2 of 2
FirstFirst 1 2
Results 31 to 43 of 43
    I stopped the d/l of the full disk. It would take quite a bit more time. If you really need it, let me know.
    I've duplicated this behavior on several tv show disk.
    I wonder if the other couple of folks who posted are using a movie dvd or a tv show type dvd.
  3. Member ChrissyBoy's Avatar
    Ok. I can replicate the issue now. (In Title 12).... I will start working on a fix. Thanks for your help.
    Glad I can help. I'm going to guess its something to do with the way some TV Episodes are structured on the disk as compared to movies. Its important in terms of making the final mpg to watch to be able to pick which "chapters" of a particular title are actually show vs. intro stuff. I don't want to watch the introduction story each time but just TV show. In order to not put the intro stuff in the final mpg I have to be able to preview the chapter material and select or unselect as the case maybe.
    If that makes any sense.
    Curious as to what you found. NOT expecting a fix at this point. Just curious as to what you discovered.
  6. Member ChrissyBoy's Avatar
    Well it is all about that fact that there are "commands" at the begining of Title 12 which tells it to start from chapter 1..... I have fixed it however and will release it tomorrow. If you would like to confirm the fix please email me for the update.
    Again thanks for drawing this to my attention and helping me get to the bottom of it.
    Glad I could help. So its the Episode thing being like its stand alone or starting over all by it self?
  8. Member ChrissyBoy's Avatar
    Sort of. The way the DVD was authored meant that playing a chapter in the middle of a Title executed some commands which said "Play from Chapter 1" - this was what you were experiencing.
    Anyway fixed in the latest build .130.
    Thanks again.
    It works well. Used it again this afternoon.
  10. Hi ChrissyBoy,
    I have just purchased VOB2MPG Pro v3.0. I have v3.0.0710 exactly. And I get the behavior described here by jsmiddleton4... is the bug back in the program? I have a VIDEO_TS folder rip of an NTSC DVD of Over the Hedge from Dreamworks. If I double-click on a specific chapter in a title it starts playing chapter 1 all the time. I tried all chapters.
    It's tough to tell which chapters you want to use if you can't preview them.
    Thanks.
    Alan-B
  11. Member ChrissyBoy's Avatar
    Its not a bug but rather that way the DVD is authored to play. If you try to play the DVD in WMP does it do the same thing?
  12. Well it works in WMP but not *very* well. If you try just after the movie starts it behaves like VOB2MPG - that is, it starts at chapter 1 all the time. However if you stop the movie and then double-click a chapter it works... but then again not for all chapters. There are 17 chapters in the title I'm looking at, and up to chapter 10-12 it works, but the last chapters will get you back to square/chapter 1, and then henceforth it won't work anymore even for the 10-12 chapters that first worked - until you stop the movie again. So I tend to want to accept your answer - it looks like the DVD is authored to make me swear.
    I'll do other tests from home with other DVDs and see. At least I can watch the individual chapters using other tools (such as VLC/WMP).
    Thanks.
  13. Member ChrissyBoy's Avatar
    Well if you can upload the DVD i am happy to look into it. I am sure that it is similar to the previous issue and therefore solvable.
  1. Replies: 2
    Last Post: 19th May 2010, 14:44
  2. Troubleshooting VOB2MPG DVD Preview
    By ChrissyBoy in forum SVCD2DVD & VOB2MPG
    Last Post: 17th Jan 2010, 15:13
  3. Preview Freezingim VOB2MPG Pro ver 3
    By 12VIBES in forum SVCD2DVD & VOB2MPG
    Last Post: 18th Nov 2009, 11:46
  4. VOB2MPG Pro preview not working & conversion slow
    By MDJH in forum SVCD2DVD & VOB2MPG
    Last Post: 22nd Sep 2009, 14:01
  5. No audio in preview or output MPG file in VOB2MPG 2.0
    By scruzphreak in forum SVCD2DVD & VOB2MPG
    Last Post: 16th Jul 2009, 12:20
