I have used ffmpegX several times to encode MOV files as FLV. I have installed the flvtool and it was adding metadata to the converted files without any trouble for a while. All of a sudden (no system changes etc.), it is failing. I've re-installed everything, no luck. There log reports...
video:11743kB audio:5265kB global headers:0kB muxing overhead 29.040135%
bench: utime=40.600s
ERROR:
ERROR: /Library/Ruby/Site/1.8/flv/stream.rb:489:in `eof?'
ERROR: /Library/Ruby/Site/1.8/flv/stream.rb:55:in `initialize'
ERROR: /Library/Ruby/Site/1.8/flvtool2/base.rb:272:in `new'
ERROR: /Library/Ruby/Site/1.8/flvtool2/base.rb:272:in `open_stream'
ERROR: /Library/Ruby/Site/1.8/flvtool2/base.rb:205:in `process_files'
ERROR: /Library/Ruby/Site/1.8/flvtool2/base.rb:44:in `execute!'
ERROR: /Library/Ruby/Site/1.8/flvtool2.rb:168:in `execute!'
ERROR: /Library/Ruby/Site/1.8/flvtool2.rb:228
ERROR: /Applications/ffmpegX.app//Contents/Resources/flvtool2:2:in `require'
Encoding completed on Mon Oct 12 20:07:38 MDT 2009
I have re-run the ruby setup routine for flvtool a couple of times, no change.
Any suggestions?
The path that is mentioned in the error lines does not make sense to me. Ruby and flvtool2 should not be in /Library for Mac OS X 10.4 or 10.5. Not sure about 10.6...
Mac OS X 10.5.8
/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/bin/flvtool2
Mac OS X 10.4.11
/usr/bin/flvtool2
I just downloaded to software and it converts form mov to flv beautifully. Now I can use some help with the flvtool2. I opened terminal, then new command, then typed in cd and dropped in the unzipped folder called -1.0.6 and hit enter - perfect. The I opened new command again typed in and typed in ruby setup.rb config and hit enter and I got a -ruby: No such file or directory -- setup.rb (LoadError). Any thoughts?
drasw
FLV videos have with flvtool still no metadata
By maltePORN in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2008, 13:16 -
stopped working?
By downer in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Jun 2004, 16:53 -
Vob Sub... stopped working
By force_star in forum EditingReplies: 0Last Post: 13th Mar 2004, 10:24 -
program just stopped working
By tryn2lern in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Dec 2003, 15:38 -
tmpgenc just stopped working - why?
By kcalczab in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2003, 06:26
Statistics
Newest guides
Latest tool updates
New media comments
