Newbie here. Only worked on SD DVD project before
If I don't want to burn then to disc (still quite expensive at $5/piece), is there any option to create just the files to play back on computer?
Thanks!
Results 1 to 16 of 16
Thread: HDV without blueray?
HDV format from a camcorder? You just plug in camcorder and do a file transfer to hard drive and play the file with any video player software.
In the old days, there are ways to embed menu in to a video file. Does such thing exist in the hdv land?
I don't remember that.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
If you are thinking of Divx Ultra and Divx authoring then no, there is nothing equivalent to that. Divx does support HD resolutions, and may support Divx authoring in HD resolution files, but these will only be playable on your PC using the Divx player. I suggest you go to the Divx website and see what they have to offer.Originally Posted by cheerful
Burn avchd made from multiavchd with menu onto dvdr and watch on blu-ray player that accepts avchd-dvdr.
Ben Johnson-I didnt take any stereos!
Or make a avchd iso and mount with Virtual CloneDrive and watch on computer.
What's the max length for AVCHD-DVDR?
Maximum amount is around 4.37 gb so a 2 hour movie bitrate is 4100kbps with 640kb ac3,a 90 minute movie is 5700kbs with 640kb ac3,that includes the overhead for authoring to avchd.
So its bitrate calculated to running time that gives you the maximum amount you put on a dvdr.Ben Johnson-I didnt take any stereos!
Remember that the overheads for authoring an AVCHD formatted disc are far higher than those required for authoring a standard DVD. I aim for a target size of 4200 MB for the M2TS stream. The authoring overheads eat the rest of the disc.
For an mkv file i find 4050 kb the max size when i author to avchd due to the overhead which is around 300mb for a 4.37 gb dvdr.
What's a reasonable bitrate for a full HD DV video (1920x1080, 24 fps)?
Thanks!
Where can I find a bitrate calculator that can deal with avchd-dvdr (has the correct information about the overhead)? DVD-HQ does not have it listed.
Thanks!
I use VideoCalc and set disc size to custom 4200mb for avchd-dvd5 and 7300mb for avchd-dvd9.5mbps and up for 1080.
I found that a Sony HD camcorder is producing 1440x1080 MTS at about 8 mbps. It's from a friend so that I don't know if the setting has low bitrate or sth like that. The video quality is reasonable.
It would mean for home video, even 8 mbps is good enough, right?
it never happen to meOriginally Posted by guns1inger
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD)Replies: 12Last Post: 23rd Dec 2011, 20:44 -
Need everything BlueRay, what's good for various uses?
By overloaded_ide in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2011, 23:17 -
BlueRay Shrink
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 11th Jan 2009, 09:48 -
MKV to blueray
By NormaJ in forum Video ConversionReplies: 6Last Post: 31st Dec 2008, 12:43 -
From HDV shooting to HDV watching
By MI6 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 26th Apr 2008, 13:05
