Hey guys!
I've been putting a compliation of photos, videos and music from a recent holiday using Ulead Videostudio 11.
When I have finished compiling it all together I chose the 'Share' tab, Create Video and chose custom settings. When the save screen appeared I chose options, now all I changed was the frame size from 640x480 to 720x576 and In the compression tab I changed the audio type from Mono to Stereo which automatically changed the audio bit rate to 128kbps.
Now the output video is fine, the only problem is the size......10.4gb! And the video is only 5mins 57secs!
Is there something I have done wrong?
I'm guessing it's uncompressed and you forgot to use video compression
There doesn't seem to be an option for compression
Best HD output for Videostudio Pro X3?
By yic17 in forum EditingReplies: 1Last Post: 8th Feb 2011, 21:10 -
Widescreen Output Using ATI Theater 650 Pro and Ulead VideoStudio X2
By waldodiodio in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 10:00 -
VideoStudio X2 Pro max bit rate?
By Mike82 in forum Authoring (Blu-ray)Replies: 1Last Post: 26th May 2009, 22:56 -
help with Ulead videoStudio?
By wamit in forum CapturingReplies: 4Last Post: 24th Apr 2009, 08:27 -
ULEAD VideoStudio trim
By dcmoser1952 in forum EditingReplies: 3Last Post: 24th Feb 2009, 14:43
Statistics
Newest guides
Latest tool updates
New media comments
