  1. Member bithead9's Avatar
    I have implemented SATA/IDE converter for the HDD and that work GREAT. But Have not had luck
    with SATA/IDE conversion for DVD unit. Anyone have luck with that ?
  2. Member bithead9's Avatar
    I did it! YES. It works. I found the right SATA bridge to be able to convert the 5045 to use SATA drives for the DVD unit. It is not the same one used for the HDD (in Mike B's thread). Here is what I tested:
    Liton 5045 recorder with a Liteon iHAS122 SATA DVD burner. It PLAYS and FAST FORWARDs ! YAY! First one so far that I have seen work on FF! Next I used a Koutech IO-ASA120 IDE to SATA II Device Adapter. I set the pins to MASTER and tested ERASE of a 4GB RW less than one minute. Did a disk prepare (after erase) took 1 minute. Play a standard DVD, no problems. Copied a couple video to DVD from the HDD and no problems. I think we have another supply of non-IDE drives we can now use in our old faithful 5045 units! And here is a place that sells the adapter: http://www.newegg.com/Product/Produc...82E16812240012
    I would be interested if anyone else has other adapters that work... Have fun folks! BTW the key to this working I believe is to buy an adapter that has the MASTER/SLAVE/CS pins to fully emeulate the IDE. That is my opinion. Since I tried other adapters and none worked until now.
    I did detect a problem. More testing is needed. I am getting some BLOCKY video. Hmm. maybe the firmware in the DVD unit needs a tweak.
    Did you ever find a solution to the blocky video?
    That seems interesting if it worked.
    Unfortunately my 5045 has a problem with actual DVD drive. It mostly won't take a disk in without some gentle force. Seems like the mechinism is not closing right. It's a Lite On 811 something DVD drive.
    What is it with this american market nobody interested in Standalone DVD units. Only thing new out seems to be the Magnavox MDR 515 and the 513 and even then you have to Mail order cant it see in a store. Geez.
    When I purchased my 5045 there was more models to chose from.
  5. Member bithead9's Avatar
    To be honest, I never did follow up on additional testing. Luckily my IDE DVD drives are working. I had bought the SATA bridge(s) mainly for the HDD adapter (which works perfect). When I am forced to use a SATA then I will get back to this...
    Almost nobody in America wants to keep anything they record. That's why DVR devices such as Tivo rule in the USA and Canada - you watch and delete and get on with your life. Those who like to keep copies of what they record are in a very small minority. I have found that a lot of Americans are obsessive about "clutter" and this is one of the reasons they like DVRs - it saves them from themselves as if they had DVD recorders they'd be storing tons of discs.
    In other parts of the world, it's the exact opposite. DVRs are generally unpopular as consumers there ask "Why on earth would you want to record something you can't keep?".
    The manufacturers abandoned the North American marketplace because there was simply no demand for DVD recorders. They are reacting to supply and demand. If you look on Amazon you can find a few other recorders beside the Magnavox ones, but you are right that you will have to buy them online and not in stores.
  1. replacement DVD drive for Liteon 5045
    By spacepiggy in forum DVD & Blu-ray Recorders
    Last Post: 9th Feb 2006, 13:40
  2. Copy from a Liteon 5045 without DVD working?
    By Raymond Cuttill in forum DVD & Blu-ray Recorders
    Last Post: 2nd Jan 2006, 20:56
  3. New firmware for Liteon 5045 posted
    Last Post: 11th Sep 2005, 10:52
  4. liteon 5045 Firmware
    By dje007 in forum DVD & Blu-ray Recorders
    Last Post: 23rd Jul 2005, 17:05
  5. Liteon 5045 saves a failed Liteon 5005 disc
    By leaglebob in forum Newbie / General discussions
    Last Post: 28th Mar 2005, 14:40
About   Advertise   Forum   RSS Feeds   Statistics   Tools
