    Hello guyz,
    I really have a strange problem here, never happened before.
    I've a working MPEG-2 video, without any problem (if I play it with WMP, there are no errors), but when I load it into Vegas (version 9 or 8, it's the same), and I simple play it, sometimes the video-image freezes, for a few seconds, like if the video is damaged.
    This happens for 2-3 seconds
    PS: This happens on different computers too, I tried a Vista 64bit 8GB RAM, and same problem!
    Any idea about that?
    Chris
  2. Vegas is not just playing the video like WMP, it is (in effect) rendering a small version of it within a complex video editing program that has a lot of other things potentially going on.
    Your video is most likely not damaged, you are just expecting Vegas to play video as efficiently as a media player that does only media playing.
    A few things to try/consider:
    1. set your video preview window to a smaller size and quality, such as draft or auto
    2. select a region where this is happening and loop playback. The freezing on a frame for a few seconds should stop after it loops through playing back the same section several times.
    3. set Vegas to pre-render to RAM (or something like that)
    4. in preferences, set the amount of RAM allocated to dynamic RAM preview to a higher number (this is in Vegas 6, I assume they carry a setting like this forward to newer) versions
    Enable multi core preview support as described here.
    http://www.dvinfo.net/forum/what-hap...-who-knew.html
    Here are some more good tips http://www.bhitchcock.com/content/node/228
    thanks for the reply guyz, I will try the things you said.
    Anyway this problem is going to be on the rendered video too (i'm doing a cam mix), so it doesn't seem just a problem of "preview".
    What do you think?
    Just checked and in Vegas 9 the multi-core preview is already TRUE so enabled!
    I tried everything posted here but still no solutions.
    I tried to demux the same video with tmpgenc plus and I didn't get this problem like Vegas.
    Here you can find a little clip (2 MB) of what I mean with "freezing".
    http://rapidshare.com/files/29518291...Creep.zip.html
    Into 4 different PCs (and different versions of Vegas), I get the same problem!
    Any idea?
    Ty
    Chris
    I can't reproduce the freezing on your sample clip with vegas , or any media player
    There is distortion/pixellation near the end of the clip, but that's likely from the cut GOP, but it plays through it without freezing.
    Right, maybe "freezing" wasn't the correct word to use (this usually means a blocked video or program).
    I mean the distorsion/pixellation you can see at the end of the clip, that's the problem I want to resolve!
    The video continues, and audio too, but I got a few seconds of this distorsion.
    This happens different times into the video.
    How can i fix that?
  1. Replies: 2
    Last Post: 29th Oct 2008, 17:49
  2. Vegas 8 showing image too bright on finished video
    By stantheman1976 in forum Editing
    Last Post: 18th Aug 2008, 15:33
  3. Replies: 4
    Last Post: 11th Jul 2007, 04:29
  4. How to display an image in video for few seconds?
    By method in forum Newbie / General discussions
    Last Post: 1st Feb 2007, 10:04
  5. distorted image on music video
    By LDinOR in forum Newbie / General discussions
    Last Post: 10th Mar 2003, 20:55
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
